Logan lathe
this thread has 2 replies and has been viewed 324 times
Old 09-11-2019, 05:37:47 PM
Rod in MN Rod in MN is offline
Default Logan lathe
HI I have a Logan, Montgomery Wards Lathe Model 54-2130
Ser# 8081.
I need to know how the wires from the Switch is wired to the
Motor? I lost the sheet with my wiring drawn on. So i'm a
little bit lost ?
Thank You
Rod in MN
Old 09-13-2019, 08:33:49 PM
ronm ronm is offline
Default Re: Logan lathe
Rod,
The last I knew Logan was still in business, now known as Logan Actuator Co., & run by a member of the Logan family. He still supported the lathes to some extent, so a wiring diagram shouldn't be a problem.
Maybe Google Logan Actuator & see what comes up...
Smokstak member #442
Old 09-13-2019, 09:40:08 PM
There is not enough info in your question to even hazard a guess. Single phase, single rotation wired thru a toggle switch? Single phase, dual rotation wired thru a reversing drum switch? Dual speed?
Or 3 phase single rotation, or dual rotation, make it a nightmare and dual speed too? Maybe DC?
How about some pics, because you know, they can be worth a 1000+ words.
The Littlest Logan Lathe dalmatiangirl61 Machine Shop and Tool Talk 71 11-27-2017 04:54:44 PM
Logan model 850 lathe Marc B Machine Shop and Tool Talk 3 01-17-2017 12:23:11 PM
Logan Lathe Bryant Machine Shop and Tool Talk 14 12-07-2015 12:45:50 PM
Logan Lathe john dodd Scale Model Engineering 10 12-04-2015 09:02:38 AM
Small Logan Lathe GarysToys Machine Shop and Tool Talk 5 06-26-2010 10:16:36 PM
