What do I have here? Lathe tool?
this thread has 7 replies and has been viewed 638 times
Old 09-18-2019, 07:37:51 PM
Ed Allandar's Avatar
Ed Allandar Ed Allandar is offline
Default What do I have here? Lathe tool?
Recently purchased a small lathe and this was in with the tooling. I'm a want-to-be machinist and have no idea what it is or if there is any value but I'm curious what it is and how it was used. It is about 14.5" long x 7.5" high. 1/4 square shaft out the one end. only marking seems to be VNM??T 0 11-259
Thanks in advance
ID:	344377   Click image for larger version
ID:	344378   Click image for larger version
ID:	344379   Click image for larger version
The Following User Says Thank You to Ed Allandar For This Post:
Old 09-18-2019, 08:07:36 PM
PFT's Avatar
PFT PFT is offline
Default Re: What do I have here?
If the hollow keyed shaft makes the slide move back and forth, then I would guess that it is a shaper attachment that could be used to cut internal keyways.
PT
Old 09-19-2019, 01:29:08 AM
Or its a cross slide off of another lathe/machine that previous owner used or meant to use as some type of attachment. What kind of lathe did you get? Does this piece seem to match it? VNMT could be Van Norman Machine Tool, or just a casting#?
Old 09-19-2019, 09:53:25 AM
Maybe some sort of purpose-built milling vise for a lathe?
Pete Stanaitis
Old 09-19-2019, 11:07:53 AM
Default Re: What do I have here? Lathe tool?
Thanks everyone had two confirmations from a machinist site identifying it as a slotter attachment for a Van Norman milling machine used for cutting internal key ways. Thanks again for the response.
Old 09-19-2019, 03:38:04 PM
If you decide to sell it, I have a Van Norman mill it will fit.
Old 09-20-2019, 04:00:59 PM
OTTO-Sawyer's Avatar
Looks like a Shaper attachment to me. . .
May or may Not go with the lathe you bought, but I'm guessing NOT unless your lathe has an extra drive unit on it to power that.
Old 09-20-2019, 04:02:50 PM
And if I'd read ALL the comments before replying I would have seen you already got your answer.
American machine and tool co small lathe help MR.22 Machine Shop and Tool Talk 4 07-01-2017 10:44:26 AM
Lathe parting tool recommendations Dustin D Ehli Machine Shop and Tool Talk 24 01-22-2017 10:19:22 PM
Knurling tool for lathe Reed Engine Machine Shop and Tool Talk 15 01-01-2017 02:04:13 PM
Lathe part? Tool and Die part? Please Help :) regman Machine Shop and Tool Talk 7 07-19-2012 10:44:28 AM
unknown lathe tool Edgar Machine Shop and Tool Talk 2 03-28-2012 12:13:37 AM
