Superior 25hp
this thread has 10 replies and has been viewed 2305 times
Old 07-25-2008, 09:24:58 PM
fixer1952 fixer1952 is offline
Default Superior 25hp
I am restoring a Superior 25hp and looking for the serial # to get what year it was made. The ID plate is missing any help??
Old 07-25-2008, 10:39:53 PM
Rich Hudak Rich Hudak is offline
Default Re: Superior 25hp
I had a 35hp that had the serial number on the back of the mag bracket. it matched the tag. But if your engine has a mag bracket, check it out, it might be numbered.
The Following User Says Thank You to Rich Hudak For This Post:
Old 07-26-2008, 11:29:40 AM
65vette396 65vette396 is offline
Both of my superiors as well as all the others I have seen have had the numbers stamped in the end of the crank. Drew
The Following User Says Thank You to 65vette396 For This Post:
Old 07-26-2008, 04:05:14 PM
Doug Waggonner's Avatar
As far I as know there isnt any serial # list for the "oil country" 4 cycle type Superiors. Has one surfaced somewhere? For the late model "1927 and later" 2 cycle Superiors the 1st two numbers of the serial # is the year of manufacture.
The Following User Says Thank You to Doug Waggonner For This Post:
Old 07-26-2008, 09:43:35 PM
I haven't looked on the crank but there are #'s stamped on the fly wheels which is "L71 91" on both fly wheels inside and outside, my mag bracket is from another engine??
Old 07-27-2008, 08:41:49 PM
There is a number on the crank but it starts with a letter like "R" on one side and "L" on the other need help
Old 07-27-2008, 08:44:01 PM
There is a number but it starts with a letter "R' one side and "L" on the other which could be left and right followed by #71 91
Old 07-27-2008, 08:54:19 PM
When we restored the 35hp. The only part that was serial # was the mag bracket. But the 20hp we have, has the wheel hubs and crank end stamped. Doug is right, I haven't seen a serial # list either. Does your head have the small plate in the middle, or the one big plate the covers the whole front of the head?.
Old 07-28-2008, 09:14:04 AM
Walt Roys Walt Roys is offline
In Memory OF
Hey Doug or anyone else,
What is a 25 0r 30 HP superior worth these days? I have a line on a 30 and was wondering what to offer.
I have to get it pretty reasonable cause I have to haul it a long ways to get it to Washington. Also what does a 30 weigh?
Walt
Old 07-28-2008, 03:19:10 PM
Hi Walt
It depends on several factors, as with all old engines.
Lets Say best case scenario, a 25hp Superior in its working clothes, all #s match, orig paint, no cracks, welds ect. Super Good bore, tons of compression runs like a swiss clock....$4500 to $6500 range <~~ now a super shiney paint job engine that meets these spces too would bring this kind of price too. "I'm just fond of engines in thier work clothes"
The mid range of the spectrum, 25hp Superior has repairs, needs a little TLC but runs OK $2500-4500 range.
Missing parts may or may not be stuck, needs a little more than just TLC $1500 to $2500
Now These Estimates are my own. I've seen em sell for A WHOLE LOT MORE.....but I've also seen them sell for a WHOLE LOT LESS. it all depends, you know what I mean Hope to see you down here in October Walt!
Old 07-28-2008, 07:21:09 PM
The front plate is just inside of the head bolts, from what I have read the front cover reads Superior Gar Engine and this is pre 1927. the crank and flywheels have matching #'s my mag bracket is from another engine but it is the same area so I will look .Thanks
25hp Jones Zach Williams Oil Field Engines & Related Equipment 0 06-30-2007 07:14:41 PM
25hp Titan David Greenwalt Hit & Miss Gas Engine Discussion 6 05-17-2005 10:05:28 AM
25hp Superior weight? Bruce Sutton Hit & Miss Gas Engine Discussion 7 01-12-2005 09:17:59 PM
IHC 25hp Titan Craig A Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 11-27-2004 08:44:30 PM
Bessimer 25hp Allen Antique Engine Archives 8 12-18-2000 07:35:41 PM
