Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
72 Starter Rack
this thread has 1 replies and has been viewed 1360 times
Old 12-29-2008, 08:02:47 PM
blake in spokane blake in spokane is offline
Default 72 Starter Rack
What is the purpose off the last tooth on the starter rack? should it loose, adjustable, tight? Thanks - Blake
Old 12-29-2008, 08:49:20 PM
Oilzum's Avatar
Oilzum Oilzum is offline
Default Re: 72 Starter Rack
The tooth should slide freely and be spring loaded. It helps the teeth mesh when you engage the starter.
Hope this helps.
T40 starter Hoodeleydoo Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 08-26-2008 10:48:15 PM
Help with a starter montess Generators & Electric Motors General Discussion 13 06-21-2008 11:49:21 AM
CAV pump sticky rack Contaucreek Vintage Diesel and Oil Stationary Engines 4 09-22-2007 04:00:23 PM
Need good photo of Delco battery rack kd4hsh Generators & Electric Motors General Discussion 0 10-15-2004 01:03:10 PM
J.D. G STARTER $80.00 randy buff Generators & Electric Motors General Discussion 0 10-07-2003 10:35:41 PM
