Steam Engines
Help! Pinion Gear
this thread has 5 replies and has been viewed 1641 times
Old 02-09-2009, 03:33:24 PM
Kevin Stewart Kevin Stewart is offline
Default Help! Pinion Gear
I'm trying to figure out what the pinion gear on my 1911 36hp Case Steam Traction engine is made from. Is it cast iron, grey iron, ductile, or cast steel? Please help. Need to have new one cast. Contact me here or spyrodevil@aol.com. Thank you!
Old 02-09-2009, 04:52:39 PM
George White's Avatar
George White George White is offline
Default Re: Help! Pinion Gear
Get ahold of Kory. He does good work and will know what you need. kory@andustries.com. He is also listed on the sponsor page if you would like to go to his web site. Hope this helps ya.
Old 02-09-2009, 10:04:09 PM
DaveWachter DaveWachter is offline
Call john haley he probley has them in stock .john has alot of case goodies .he lives in ill and i do not have his phone no. In front of me dave wachter ill thresher no 135
Old 02-09-2009, 10:35:41 PM
Dave,
I just sent Kevin a PM with John Haley's number.
Mike
Old 02-10-2009, 12:15:55 AM
Colin's Avatar
Colin Colin is offline
Hi- Which pinion do you need? The crank shaft one should be reversible. although you likely dont want to do that. have seen it done on 75s though. it will be a cast iron gear(non weldable-{non buzzboxable})
do you have any pictures of your engine?
Last edited by Colin; 02-10-2009 at 01:07:13 PM. Reason: Non BuzzBoxable, For Lawrence>>> :)
Old 02-10-2009, 11:13:15 AM
GaarScott's Avatar
GaarScott GaarScott is offline
Colin,
I'm confused by your remark of non-weldable??? Why?
Lawrence
9hp Case pinion gears-Progress Brad Kelley Steam Stationary Engines, Traction Engines 47 08-15-2012 11:48:44 PM
Advance Rumely Bull Pinion Gear mank10 Steam Stationary Engines, Traction Engines 13 03-14-2008 05:17:30 PM
New Gear Source: Martin Gear + Sprocket PaulGray Hit & Miss Gas Engine Discussion 3 01-22-2008 09:54:45 AM
Sattley cam gear and crank gear timing Judson Hit & Miss Gas Engine Discussion 2 11-18-2007 07:21:11 PM
Pinion Bearing Drag Raymond Antique Farm Tractors 8 09-21-2007 12:20:10 AM
