Antique Truck Frame?
this thread has 12 replies and has been viewed 3729 times
Old 06-05-2009, 11:02:42 AM
Molinegb Molinegb is offline
Default Antique Truck Frame?
Found an old frame beleived to be from truck. Had 5.5x 19 spoked wheels. Appears to be right hand drive. The rearend has two shifters attached like a transmission. Any ideas/
ID:	55882   Click image for larger version
Old 06-05-2009, 10:06:26 PM
Rene Elliott Rene Elliott is offline
Default Re: Antique Truck Frame?
My guess would be British, most American manufacturers had standardized to left hand steer by 1920. The front axle spring arrangement may be a helpful clue.
Old 06-12-2009, 11:04:26 PM
oldgoaly oldgoaly is offline
You might post a question here http://www.oldclassiccar.co.uk tt
Old 06-13-2009, 02:18:10 PM
Unless it is a two speed rear, it might be something like a Cotta transmission c. WW1 that mounted right to the differential (Linn briefly used a 3 speed Cotta, but under heavy loads it would jump out of gear and free wheel down steep grades, not good).
Old 07-07-2009, 07:49:58 AM
Stuart Landry Stuart Landry is offline
Hello, early CHEV had a front end set up like your chassis, I'am not shure how the diff. was set up on a chev. but STUDEBAKER had a trans.-axle with standard 3 speed "H" pattern , they use only two rods to connect the gear shift ,just like yours ,
i would think early chev. !
Old 07-08-2009, 06:07:39 PM
franklinman franklinman is offline
I think what you've got is from a mid teens Overland car.
Old 07-09-2009, 09:28:44 PM
Ernest Portner in Rome, NY has a c. 1923? Chevy front axle, doesn't look the same as this? Someone has been listing a pair of early Chevy wheels in the local pennysaver for $100 but I don't need to build a "vintage" trailer that bad.
Old 12-18-2009, 06:31:17 PM
truklodyte truklodyte is offline
It may just be an old two speed rear end.
Old 12-18-2009, 07:16:21 PM
Jeff Chattin's Avatar
Jeff Chattin Jeff Chattin is offline
Some transaxles used in studebaker during teens
Old 03-23-2010, 12:21:55 PM
Rear springs have ten leaves in each spring and are mounted upside down as compared to normal. Distance from front to rear axle 110 inches. Some of part numbers on frame are left front spring clamp E4547 with a Y in a diamond.Right E4549. Front springs have 8 leaves.Brakes have part number 20891 and 20890 with a diamond and a B in it. Left axle is 17 1/2" and right is 25 1/2". As in pix there is a hump above differential in frame. Any ideas? Diamond T?
Old 03-24-2010, 01:43:28 AM
DesertExplorer DesertExplorer is offline
Molinegb,
Try the Antique Automobile Club of America. They have a "What is it?" forum. I've always been able to get frames, axles, etc... identified on their site. Here is a link.
http://forums.aaca.org/f170/
Hope it helps.
The Following User Says Thank You to DesertExplorer For This Post:
Old 03-25-2010, 10:13:15 AM
Just too add. The tires are 19" but 26".
Old 03-29-2010, 12:21:04 PM
Frame is not a truck. It is a frame from Saxton Six car from mid teens. Front axle has been reversed. Thanks for the input.
Long Frame or Short Frame MCH02 Maytag Engines and Collectibles 20 06-20-2009 07:57:55 PM
1918-1930 Antique Mack Truck Wheel Set rare metal spoke cushion tires Lilbethy Antique Autos and Trucks 1 04-09-2009 11:56:11 AM
Dream Antique Truck or Car 40-140RumleyKid Antique Autos and Trucks 41 12-20-2008 03:43:15 PM
Short Frame - Long Frame blake in spokane Maytag Engines and Collectibles 3 10-13-2008 12:00:39 AM
Trailer hitch, truck frame cracking KeithW Trucks, Trailers and Hauling for Shows 16 02-25-2008 12:10:15 PM
