Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Stationary Engines
Vintage Diesel and Oil Stationary Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
Does anyone know anything about a McCord oiler?
this thread has 2 replies and has been viewed 1517 times
Old 07-30-2009, 10:15:26 AM
Temple2426's Avatar
Temple2426 Temple2426 is offline
Default Does anyone know anything about a McCord oiler?
Old 07-30-2009, 03:25:40 PM
J.R.Smith J.R.Smith is offline
Thumbs up Re: Does anyone know anything about a McCord oiler?
Hello! Yes a little. Just got done witha 10 line for a Anderson. j.r.
Old 07-30-2009, 03:35:17 PM
Temple2426's Avatar
Default Re: Does anyone know anything about a McCord oiler?
great can you tell me what the outlet pressure should be and how complecated the 5 line oiler would be to rebuild. the pump when you prim it oils but when you use the actuator on the left side it does nothing. can you help. if so call me @ 601-941-0538 thanks! matt
McCord Lubricator Identification Tractasaurus Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 12-29-2011 11:30:17 PM
How much pressure should a McCord force feed put out Temple2426 Vintage Diesel and Oil Stationary Engines 6 02-12-2010 08:50:15 PM
Need help with a mccord oil pump! Temple2426 Vintage Diesel and Oil Stationary Engines 0 07-24-2009 06:28:48 PM
McCord Lubricators used on tractors? Tractasaurus Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 08-14-2007 12:04:54 AM
McCord Lubricator Tom weatherford Antique Engine Archives 1 05-01-2004 02:21:58 PM
