Steam Engines
McCord oiler?
this thread has 4 replies and has been viewed 1661 times
Old 08-08-2009, 10:45:37 AM
Temple2426's Avatar
Temple2426 Temple2426 is offline
Default McCord oiler?
Does anyone know anything about a McCord force feed oiler?
Old 08-08-2009, 11:43:08 AM
Allen
Default Re: McCord oiler?
Other than I have one? I can tell you how to adjust the feed rate. (the collar around the plunger screws up and down) I just learned how to do THAT last week.
About all I know
Old 08-08-2009, 08:18:26 PM
Temple2426's Avatar
you are talking about the the part that pumps not the nuts on the top? I have a continental gin engin 55h oil engine and it goes on it it is a 5 site oiler and the journal bearing slung in the engine and our thinking was that the oiler wasnt oiling enough so i tested the oiler with a 100 psi gage and it peged out with two pumps on each site so i dont think that it was the problem. how much pressure should it put out? thanks!!!
Old 08-08-2009, 08:24:37 PM
Allen
The threaded part that sticks out the top that has the little plunger that goes up and down in the center. The further down you screw the collar, the longer the pump's working stroke. We found that out almost by accident while looking for a regular adjusting "screw".
Old 08-08-2009, 08:50:25 PM
Temple2426's Avatar
OK got that thanks for the advice!!!!
McCord Lubricator Identification Tractasaurus Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 12-29-2011 11:30:17 PM
Does anyone know anything about a McCord oiler? Temple2426 Vintage Diesel and Oil Stationary Engines 2 07-30-2009 03:35:17 PM
Need help with a mccord oil pump! Temple2426 Vintage Diesel and Oil Stationary Engines 0 07-24-2009 06:28:48 PM
McCord Lubricators used on tractors? Tractasaurus Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 08-14-2007 12:04:54 AM
McCord Lubricator Tom weatherford Antique Engine Archives 1 05-01-2004 02:21:58 PM
