Oil Field Engines
Need help identifying old "Wind Wheel" oil field engines
this thread has 5 replies and has been viewed 1868 times
Old 06-26-2010, 10:58:50 PM
kcroger kcroger is offline
Default Need help identifying old "Wind Wheel" oil field engines
Any information you can provide me about these old engines will be appreciated. I know nothing about them other than that they came from old oil rigs. The previous owner probably had at least one of them up and running, but I have no idea if they run. There are 3, to me they appear to be the same model but I'm not sure. The model looks like Kohler K330-ccf or K830, I can't tell. Thanks for looking.
Old 06-26-2010, 11:00:50 PM
Default Re: Need help identifying old "Wind Wheel" oil field engines
Old 06-27-2010, 06:54:31 AM
Tom Weatherford Tom Weatherford is offline
They came in single and twin cylinder. I have a twin. Have not had it running yet.
Tom
The Following User Says Thank You to Tom Weatherford For This Post:
Old 06-27-2010, 09:46:22 AM
Question Re: Need help identifying old "Wind Wheel" oil field engines
What was the purpose of these units?
Old 06-27-2010, 12:47:42 PM
Brian Lynch's Avatar
They used them to run a oil well pump jack. At least that's what the ones I've seen were doing.
The Following User Says Thank You to Brian Lynch For This Post:
Old 06-27-2010, 02:56:56 PM
Thanks for the replies and information. Anyone else know anything about these units? Like when it was put out, ect? I can't find much on the "wind wheel" online. I did find this youtube video that shows one of these things in action, thought i'd post it here.
http://www.youtube.com/watch?v=kjFtTi795kU
The Following User Says Thank You to kcroger For This Post:
It whispered from the side of the road "653 Wheel Horse" JKWidener Garden Tractors and Mowers 2 09-19-2009 08:52:47 PM
MEP 003A needs "field flashing" to make power Jiggy Military MEP and Aircraft Gen-Sets 2 12-07-2008 11:50:30 AM
Wind Wheel Engines Russell Farmer Oil Field Engines & Related Equipment 0 10-24-2006 09:51:23 AM
Question? "Oil Field" or "Industrial" David M. Hammer Oil Field Engines & Related Equipment 1 12-27-2005 12:15:19 PM
Generator field "Flashing" Bob (ND) Generators & Electric Motors General Discussion 2 01-05-2004 12:11:35 PM
