Oil Field Engines
Need help starting a 15hp reid
this thread has 5 replies and has been viewed 1861 times
Old 10-01-2010, 09:32:49 PM
Henry Macomber Henry Macomber is offline
Banned
Default Need help starting a 15hp reid
Recently aquired a 15HP Reid, my first engine of this type, I've been collecting engines for 20yrs, never got into this type of engine before.It has a hot tube and a magneto.I have tried starting this engine and all I get is a hit or two and it stalls. What I need is someone with knows these engines to give me step by step instructions on how to start it, from how much the gas valve should be opened and on.Standing behind the engine the charge cylinder is on the right (I beleive it's refered to as a charge cylinder)
Old 10-02-2010, 09:21:36 AM
Farmer John Farmer John is offline
Default Re: Need help starting a 15hp reid
start with the piston on the charge cyl all the way in,then roll flywheels foward towards the cyl i/2 turn then back the oppisite direction 1/2 turn till the charge cyl piston is back all the way then in one good hard roll roll flywheels backwards ( top of flywheels toward cyl ) to start ..i light the intake before starting and get the flame 6-8 inches high to set my fuel...reids flood very easy best to start lean and work your way up..once it fires tap the gas valve open a little more till its running .. the air intake plays a big part also so give it about1/2 way open to start you may have to choke it a little too... if you use your foot in the spoke kicking it remember on the hot tube it can fire at any point on the compression stroke.so do not be in that thing on compression you do not want to ride the flywheel ... hope this helps as i was in your position this spring learning how to get my 12 going,but i had some good help and made some friends in the process..if i missed any thing someone else chime in cause i've only had 1 cup of coffee this morn......good luck.....john
The Following 2 Users Say Thank You to Farmer John For This Post:
Old 10-03-2010, 09:55:28 AM
When encountering a Reid that will fire once or twice then quit the first thing I check is the crossover valv. It might be sticking or the nut on the bottom may have loosened. Bill Klein
The Following 3 Users Say Thank You to W.P.Klein For This Post:
Old 10-03-2010, 03:06:36 PM
Rod Fielder Rod Fielder is offline
what regulator are you using. are you using the hot tube or the mag. does it have a governor and if so is it hooked up. do you have an acumulator tank. any photos will help. i have helped 5 people get their reids running in the past 3 months, one allready today. e-mail me if you want.
rod
Old 10-03-2010, 08:11:07 PM
ROD helped me get mine going... i spent a lot of time talking with him.damn good guy i cant say enough good things or thank him enough !!!!!!!
The Following User Says Thank You to Farmer John For This Post:
Old 10-03-2010, 09:15:23 PM
afretired afretired is offline
Listen to the guys on here, they really helped me get my 15HP Reid going. Check out some of the help they gave me on my posts. One thing to take to heart, don't use your foot to ride the spokes to crank it. I'm still hobbling around with a brace on my leg where it kicked me at my first engine show on 19 June.
Dave.
The Following 3 Users Say Thank You to afretired For This Post:
I need help with a 15hp Reid afretired Oil Field Engines & Related Equipment 31 06-01-2010 03:00:16 PM
1903 15hp Reid Bob Hanauer Oil Field Engines & Related Equipment 9 04-18-2009 03:11:59 PM
15hp Reid Info Jim Gorter Oil Field Engines & Related Equipment 4 01-11-2006 12:15:47 PM
15hp Reid AFretired Antique Engine Archives 2 07-11-2004 09:05:16 PM
15hp Reid Pix chase Antique Engine Archives 0 01-04-2003 02:00:49 AM
