Welding Shop
Old Hobart Bro's Welder
this thread has 4 replies and has been viewed 2225 times
Old 11-17-2010, 09:29:35 PM
ford390gashog ford390gashog is offline
Default Old Hobart Bro's Welder
I bought a vintage Hobart Bro's welder to use it is in good shape trying to find out any information I can on it. The data plate is very worn and I have only been able to get a few numbers off it.The engine information was not stamped on the plate it was left blank. It is powered by a Wisconsin TJD engine. Is this welder AC or DC output? I have never seen one like it.Any help would be great.
Amps:200
AC 110/220 42amps
Model W-225
Old 11-20-2010, 07:52:42 PM
BGunn BGunn is offline
Default Re: Old Hobart Bro's Welder
Post a picture of it, sounds like one that my brother has. We went through it a few years ago and fixed it up and it has worked very well since.
Old 11-27-2010, 09:07:56 PM
Okay got some more info on the unit still need to get some pictures of it.
MODEL:W-225
AMPS:200
VOLTS:25
DUTY CYCLE:100%
SPECS:4295A
SERIAL:AAW-52425
AW1954
RPM:1800/2200
VOLTS:110/220
AMPS:42/21
KW:5
This is from the data plate. Thank You for all your help!!
Old 11-27-2010, 09:14:37 PM
clintonmetalcraftsman clintonmetalcraftsman is offline
yes pictures would be helpfull. Is there a selector switch to go from dc to ac? that would be a good indication, it sounds like it has aux ac power, is there an ac plug on it? Show pictures of the control panel
Old 11-27-2010, 11:31:20 PM
No switch for a/c to d/c operation it has two 110 volt outlets on the front and two 220 v outlets on the front.
Old Hobart Welder/Generator jtfrench Welding Shop 5 04-19-2011 08:31:40 PM
Hobart Welder Color Brian Howard Welding Shop 1 10-20-2008 04:10:00 PM
old hobart welder Dan Potter Welding Shop 1 06-16-2007 01:54:52 PM
Old Hobart Welder DaveHath Welding Shop 7 01-10-2006 09:17:27 AM
DCC-353-P Hobart Welder Rob-n-LA Welding Shop 2 07-17-2004 03:55:11 PM
