Oil Field Engines
25hp Superior
this thread has 3 replies and has been viewed 2004 times
Old 11-25-2010, 09:32:58 AM
moparguy moparguy is offline
Default 25hp Superior
Could someone give me a measurement from the center of the crank to the front lip where it is machined on the Cylinder???
I`m putting a diff cylinder on my 25 as the original one was scraped before i got the engine.
Thanks Paul
Old 11-27-2010, 06:41:43 AM
Steve NW Ohio Steve NW Ohio is offline
Default Re: 25hp Superior
I will try to get you that measurement today.
Steve
Old 11-28-2010, 06:10:20 AM
From the center of crank-shaft to head mounting surface is 65-3/8" on mine.
Old 11-28-2010, 05:23:47 PM
Thanks,
I had the holes all ready drilled and tapped, but from a wild guess and measurements off a 25hp of a diff make that looks all most identical to the Superior, i got it right on the same measurement you gave me.
Thanks Again, Paul
25hp Superior Tom Weatherford Oil Field Engines & Related Equipment 1 10-24-2010 10:15:29 PM
25hp superior exhaust valve box Harold Price Oil Field Engines & Related Equipment 0 08-24-2009 01:56:35 PM
Help with Propane with 25hp Superior J.R.Smith Oil Field Engines & Related Equipment 6 08-31-2008 08:05:27 PM
Superior 25hp fixer1952 Hit & Miss Gas Engine Discussion 10 07-28-2008 07:21:09 PM
25hp Superior weight? Bruce Sutton Hit & Miss Gas Engine Discussion 7 01-12-2005 09:17:59 PM
