Mig welding on generator frame, Damage to electricals?
this thread has 3 replies and has been viewed 4188 times
Old 12-16-2010, 01:18:43 AM
Motorhead's Avatar
Motorhead Motorhead is online now
Default Mig welding on generator frame, Damage to electricals?
I have a Dayton/Generac 8kw diesel enclosed generator set. The unit is self contained. I wanted to repair the rusted battery rack on the main frame of the generator. I have a Mig welder but I am concerned about welding and any electrical feedback damaging the gensets component boards. Is it ok to weld on it or not?
Old 12-16-2010, 07:23:21 AM
armandh armandh is offline
Default Re: Mig welding on generator frame, Damage to electricals?
if nothing is connected to the frame probably not a problem but
engine wiring uses the frame as a return and often
the engine and gen wiring are in the same housing
possibly interconnected [I have one of each]
got a big tip for the O2/C2H2 ???
[and a lot of coat hangers]
Old 12-16-2010, 03:41:05 PM
Exclamation Re: Mig welding on generator frame, Damage to electricals?
Make sure you have good ground contact, and that it is close to the point of welding. This will help diminish stray voltage issues.
Old 12-16-2010, 05:59:38 PM
Tom Marshall Jr.'s Avatar
Tom Marshall Jr. Tom Marshall Jr. is offline
On new Big trucks a sticker says to unhook the battery cabels be fore welding to protect electric components. Keep the cabels from touching anything and you should be good to go.
Short Frame - Long Frame blake in spokane Maytag Engines and Collectibles 3 10-13-2008 12:00:39 AM
WWll welding generator? Ben Clarke Military MEP and Aircraft Gen-Sets 7 05-15-2008 09:02:06 AM
WWll welding generator? Ben Clarke Military MEP and Aircraft Gen-Sets 0 05-09-2008 09:19:28 AM
damage to 12 v generator/starter if no battery attached ??? werfymmot Onan Generators 0 04-04-2006 03:47:48 PM
Open frame generator or alternator Jason Barnes Generators & Electric Motors General Discussion 2 07-21-2003 05:55:23 AM
