Oil Field Engines
25hp Superior
this thread has 7 replies and has been viewed 2275 times
Old 01-28-2011, 11:58:06 AM
Harold Price Harold Price is offline
Default 25hp Superior
Why would there be counter weights on the crank on one engine but not on another one just like it?
Old 01-28-2011, 12:47:34 PM
Default 25hp superior
ID:	98979   Click image for larger version
Old 01-28-2011, 01:39:18 PM
Tom Weatherford Tom Weatherford is offline
Default Re: 25hp superior
The flywheels on one might not have built in counter weight and the other one does.
Old 01-28-2011, 09:02:42 PM
Fred Milner Fred Milner is offline
Default Re: 25hp Superior
I also have a 25HP Superior with the counterbalanced crank. It is my understanding that the industrial engines had the counterbalanced cranks. Do you think that they would put the industrial cranks and flywheels on an oil field engine if they ran out of the balanced flywheels but had the industrial stuff on hand. Most companies did what they had to do to get the engine out the door and the money coming in.
Just my thought.
Fred
Old 01-28-2011, 10:15:38 PM
Jeff Miley Jeff Miley is offline
Thumbs up Re: 25hp Superior
Harold: Beautiful Superior.
The Following User Says Thank You to Jeff Miley For This Post:
Old 01-29-2011, 09:47:22 AM
I thought that maybe the engine was us on an application that required lots of power and steady rpm’s. The weights would help keep up the HP.and rpms through the exhaust and intake cycle. I don’t know if this would be right or wrong.
Jeff thanks for the complement
The Following 2 Users Say Thank You to Harold Price For This Post:
Old 02-01-2011, 11:23:49 AM
Walt Roys Walt Roys is offline
In Memory OF
On the engines that did NOT have the counter ballance on the crank, is the ballancing done by putting holes on the inside of the flywheels? With the 20 I have ,I was guessing this was what those big rectangular holes were for. Is that correct?
Walt
Old 02-01-2011, 01:38:35 PM
speleausmining
Yes often thares holes bored out or a rectangular area to ballence out the crank. On early engines you will often see a weight bolted on to the fly wheels. Depends on the manufacturer etc. Failure to account for the crankshaft results in an off ballenced engine, excessive vibration, and premature wear to bearings etc. Nice engine I have allways admired Oilfield engines and Superior is probably #2 on my list of desirable engines.
25hp Superior moparguy Oil Field Engines & Related Equipment 3 11-28-2010 05:23:47 PM
25hp Superior Tom Weatherford Oil Field Engines & Related Equipment 1 10-24-2010 10:15:29 PM
Superior 25hp fixer1952 Hit & Miss Gas Engine Discussion 10 07-28-2008 07:21:09 PM
25hp Superior weight? Bruce Sutton Hit & Miss Gas Engine Discussion 7 01-12-2005 09:17:59 PM
