Convert Onan 5.0CCK-5DR/8462V Three phase to Single phase
this thread has 4 replies and has been viewed 3618 times
Old 06-28-2011, 06:47:32 PM
RichardD RichardD is offline
Default Convert Onan 5.0CCK-5DR/8462V Three phase to Single phase
I just aquired a 3 phase delta wound 5.0CCK-5DR/8462V natural gas in an enclosure that has very few hours on it, it almost looks new. I also have a 6.5 NH 3CR/16004M gasoline.
After researching the site I know I can wire it with 2 single phase 120V circuits but it will only have 3350 watts usable by doing this. I want to convert it to a single phase completely and I have a few options I think.
Option 1: Find a used 5.0 single phase rotor or one with a blown engine.
In the parts manual for the CCK all the 5.0 60 Hertz sets regardless of phase take he same stator 220-1821. There are only two parts that are different. The rotor and the wiring harness. The rotor for a 5.0CCK-3CR Spec R is 201-1903 and Spec V is 201-2503. The wiring harness for the 1 Phase Spec V is 338-0946 and the 3 Phase Spec R is 338-0643 (Why I mentioned the 3 Phase harness will be clear in a minute).
Option 2: Rob rotor from 6.5 NH
For the NH I only have a parts manual that goes to spec D wheras mine is a spec M. The rotor for the NH Begin Spec D is 201-1903 which is the same as the single phase CCK Spec R. The wiring harness for the NH Begin Spec D is 338-0643 which is the same as the CCK Spec R 3 Phase harness.
Option 3: Swap entire generator heads
The Generator to engine adapter for the CCK is 231-0164 which is the same as the NH Begin Spec D.
I think the easiest thing would be to swap the entire generator head, both of them have the same controls and I wouldn't have any rewiring to do.
I just wonder how many watts I could expect from the 6.5 generator head and 5.0 engine.
Thanks,
Richard
Old 06-28-2011, 08:41:20 PM
Default Re: Convert 5.0CCK-5DR/8462V Three phase to Single phase
According to Onan’s literature, a 5.0 CCK has a maximum engine potential of 5.5 KW on gasoline.
Parts manual #940-0223 covers the NH spec. A-R, you are welcome to a copy.
Old 06-28-2011, 08:46:45 PM
BTPost's Avatar
BTPost BTPost is offline
Talking Re: Convert 5.0CCK-5DR/8462V Three phase to Single phase
Your NH is a 14 Hp engine, where as the CCK is a 10 Hp engine. These are at 1800 Rpm ratings, for both.... So figure the CCK will run out of engine, long before the copper runs out of Amps, if you do a switch....
Bruce in alaska
Old 06-28-2011, 09:05:16 PM
Thanks Max, I would appreciate a copy. E-mail hocks@cybertronics.net.
---------- Post added at 08:05 PM ---------- Previous post was at 07:57 PM ----------
That's what I was thinking. It should be the safest option.
Old 06-29-2011, 07:48:56 AM
Default Re: Convert Onan 5.0CCK-5DR/8462V Three phase to Single phase
Should be in your in box.
The Following User Says Thank You to Max Thompson For This Post:
Another stupid question about converting from single phase 120v to single phase 240v! Patrick Onan Generators 7 11-30-2011 02:08:16 PM
Onan 15.0JC wiring change from 3 phase to single phase? Danile Onan Generators 6 03-11-2011 06:00:28 PM
Onan DJC 3 Phase to Single Phase Rewinding MikeywP Onan Generators 9 01-28-2011 11:08:27 PM
Onan 6kw DJB looking to change over from 3 phase to single phase meckpa Onan Generators 14 10-04-2010 09:35:45 AM
3 phase to single phase for a Onan 15JC ksmith05 Onan Generators 9 01-03-2009 02:46:58 PM
