Steam Engines
Started New Engine Project
this thread has 26 replies and has been viewed 5685 times
Old 11-08-2011, 02:20:49 AM
n47ie5 n47ie5 is offline
Default Started New Engine Project
I just started machining my new engine project based on the case 65 1/4 scale prints. I don't have any castings so i'm making all the parts from scratch. It's going to take some work, the drawings are missing some dimensions on some of the parts so i'll have to figure those out. I'm currently working on the engine cylinder. I'll post some photos if anyone is interested. Does anyone have any good photos of the case 65 slide valve?
Andrew.
The Following 2 Users Say Thank You to n47ie5 For This Post:
Old 11-09-2011, 03:40:56 AM
Default Re: Started New Engine Project
Here's some pics of the cylinder being drilled and bored...
ID:	120448   Click image for larger version
The Following 9 Users Say Thank You to n47ie5 For This Post:
Old 11-13-2011, 09:19:41 PM
Got some more work done on the cylinder, bored, honed, and ported.
Andrew.
The Following User Says Thank You to n47ie5 For This Post:
Old 11-13-2011, 09:33:38 PM
Beth V's Avatar
Beth V Beth V is offline
Andrew,
I'm not sure where in Ohio you are, but there are several 65's in Ohio that you could study. Dale Miner has a very nice one and he is a Stakker.
Good Luck
Beth
Old 11-14-2011, 12:50:31 AM
Beth,
I'm actually located near the town of Somerset OH. To my knowledge I don't think there are any Case engines nearby, but a few miles out I did see what I thought was a Case engine sitting in the corner of a new building that didn't have all the tin on it yet. It was about dusk so hard to tell, no one was there. It's a small town so I asked around and nobody knew anything about it. I do wish there were more steam people local to share info with. I know when my engine is out it does get alot of attention. People sometimes stop to look. Earlier this summer I had it out and these two kids that were driving by stopped to ask me what it was. They really have never seen a steam traction engine, and they just had to take a picture of it.
Andrew.
Old 11-14-2011, 11:35:11 AM
Pete LaBelle Pete LaBelle is offline
Wondering if you should sleeve the cylinder with a cast iron sleeve?
It would absorb oil, and therefore not rust as easily in the wet enviroment of a steam engine.
Just a thought.......
Old 11-15-2011, 01:34:39 AM
Pete, I never thought about that, but my other engine has a steel bore also and it hasn't been a problem on that one, so I think it will work ok...
Old 11-22-2011, 02:22:37 AM
OK, got a little more work done on the engine, seems like work keeps getting in the way... Here are some more pics of the progress. I want to thank those of you who have helped me with some info, and some dimensions on some of the castings.
ID:	121442   Click image for larger version
ID:	121443   Click image for larger version
ID:	121444   Click image for larger version
Old 11-22-2011, 02:24:54 AM
One more photo, couldn't get this one in the last post. This is where i'm currently at. Just starting to cut the slot in the cross head tunnel.
Old 12-04-2011, 04:57:41 AM
Slowly making some more progress. I almost have a complete engine frame now.
ID:	122366   Click image for larger version
ID:	122367   Click image for larger version
The Following 5 Users Say Thank You to n47ie5 For This Post:
Old 12-05-2011, 05:56:06 PM
Ethan C.
Andrew,
looking good . In your first post you wanted a picture of the slide valve. Heres one from the 1917 catalog with the whole engine frame, I hope this can help you out a bit.
-Ethan
Name:	Engine Frame.jpg
Old 12-16-2011, 10:41:06 PM
Got some more work done on the engine. here's the crank disk and rod...
ID:	123233   Click image for larger version
ID:	123234   Click image for larger version
ID:	123235   Click image for larger version
Old 12-16-2011, 10:59:03 PM
loggerhogger loggerhogger is offline
Nice work so far! i was wondering if you by any chance have the drawings for the governor. I have a 1/4 scale traction engine that was put out by Tearning back in the 60s. It doesn't have the governor, and I would like to build one for it.
Old 12-17-2011, 01:45:05 AM
As far as I know, drawings for Ternings governor were not available, nor do I have any idea if any exists unless someone else knows something about it? From what I know the details were a secret. I called Aaron Terning about the governors once and he would only sell a completed governor. I would love to find one to reverse engineer to find out why. Last year I built a small governor for my other engine, had 1/4" inlet and outlet. It was a non balanced needle valve type spool which actually works well for that size but I doubt that design will work for a 3/8" governor. Once I get this engine done I will probably design a new governor for it.
Old 01-03-2012, 04:33:03 AM
Photo Engine Project Progress
Getting some more done on this, more pics, crank disk, cylinder head and piston...
ID:	124703   Click image for larger version
ID:	124704   Click image for larger version
ID:	124705   Click image for larger version
Old 01-03-2012, 04:37:07 AM
Photo Re: Started New Engine Project
Here's the D-valve other parts, and the engine.
ID:	124707   Click image for larger version
ID:	124708   Click image for larger version
ID:	124709   Click image for larger version
The Following 7 Users Say Thank You to n47ie5 For This Post:
Old 04-25-2012, 02:29:42 AM
Here's a little update- making more progress on my engine. I had to put it on the back burner for a while as other things got in the way... Got the main bearings in the engine frame (ball bearings), and now in the process of making the steam chest, valve packing fitting, valve spool & rod, then on to the eccentric and eccentric strap. I have the eccentric strap cutout and it is ready to be machined. I also did 2 cutouts of the eccentric strap while I was at it so I will have an extra. I'll post some more pics later on.
Andrew.
The Following 3 Users Say Thank You to n47ie5 For This Post:
Old 04-25-2012, 07:59:12 AM
1/4case 1/4case is offline
Good to hear progress is still being made.
Old 04-30-2012, 04:54:02 AM
OK, here's some pics of progress on the steam cylinder, valve and steam chest. Currently making the valve rod guide and packing gland. Didn't have any hex stock so I had to make that too...
ID:	134384   Click image for larger version
ID:	134385   Click image for larger version
ID:	134386   Click image for larger version
Old 04-30-2012, 04:59:01 AM
More pics... Steam chest with D-valve in place, cover, the eccentric strap before machining, and the valve rod guide/packing gland fitting as it is before drilling and threading.
ID:	134388   Click image for larger version
ID:	134389   Click image for larger version
ID:	134390   Click image for larger version
Started Moline Universal project Fred Milner Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 11 05-08-2012 11:39:30 AM
Winter project #2 started... Jim Sherman Hit & Miss Gas Engine Discussion 1 11-20-2010 07:34:41 PM
The project has been started IronCity2006 Hit & Miss Gas Engine Discussion 1 02-11-2009 01:51:14 AM
The engine that started this addiction Mike F Hit & Miss Gas Engine Discussion 13 02-12-2008 01:46:57 PM
