I Got This Big Box Monday----
this thread has 12 replies and has been viewed 1645 times
Old 11-10-2016, 12:30:32 PM
Skip Landis Skip Landis is offline
Default I Got This Big Box Monday----
Monday morning i got a call from Fastenal in Great Falls. 460 miles later, i'm home with this big box. I wonder what's in it? Let's find out. Looks like there's an engine in there. Well, would you look at that! What a beauty! Came all the way from Ohio. Thanks Tom.
Name:	skips picture 1174.jpg
ID:	267711   Click image for larger version
Name:	skips picture 1175.jpg
ID:	267712   Click image for larger version
Name:	skips picture 1176.jpg
ID:	267713   Click image for larger version
Name:	skips picture 1177.jpg
Old 11-10-2016, 12:37:18 PM
Default Re: I got this big box monday----
A few more pictures, the last 2 show some minor damage. The intake valve got bent, broken plug & worse, the oiler got broken off & chipped the threads in that cylinder. Unfortunate, but not too serious. It could have been much worse. skip
Name:	skips picture 1178.jpg
ID:	267715   Click image for larger version
Name:	skips picture 1179.jpg
ID:	267716   Click image for larger version
Name:	skips picture 1180.jpg
ID:	267717   Click image for larger version
Name:	skips picture 1181.jpg
The Following 5 Users Say Thank You to Skip Landis For This Post:
Old 11-10-2016, 06:34:56 PM
Mitch Malcolm Mitch Malcolm is offline
Banner Sponsor
Skip its a long way from your place to great falls but through some beautiful country is there any snow at hwy level yet through glacier park ?
Old 11-10-2016, 06:42:41 PM
Rich Mueller Sr's Avatar
Rich Mueller Sr Rich Mueller Sr is offline
Man, Fastenal 3pl must have some real bad orangutan drivers or in the wharehouse where the are rerouted these days. I had a 3hp Challenge shipped from Ohio to, luckily NO damage other than the forklift fork hole in the side of the box, which they pulled off ,nailed down with about a dozen twist nails , it takes some doing to pull those out I found out, then they just bent the nails over and stuck the box over engine! Kerry Sanchez is who I deal with and gave a not to nice call to, maybe you should to she was going to do some chewing she said. First time I ever had one crated and first time any trouble they are starting to get a bad rep hope somone relizes it might be their jobs..
United Gasoline Engine Registry www.augermo.com
Old 11-10-2016, 07:00:04 PM
All the small box had in it was the coils, so i don't think that caused any damage. Mitch, no snow yet, just in the high country. Thanks to to those who responded, my thanks button is gone. skip
The Following User Says Thank You to Skip Landis For This Post:
Old 11-10-2016, 07:51:13 PM
James L Johnson James L Johnson is offline
Images: 38
Skip:
Very nice looking NEWWAY, and the twins run soooo well.
And the broken parts look to be an easy repair.
The Following User Says Thank You to James L Johnson For This Post:
Old 11-10-2016, 10:39:22 PM
AussieIron AussieIron is offline
Nice pick up. That damage will be ok. What is the engine number, if you don't mind me asking? Good luck getting it going, they're great to hear running. Post a video if you can. Cheers-Neil.
Old 11-10-2016, 10:56:56 PM
Dan Baalman Dan Baalman is offline
Will look great in your shed. Thanks so much for letting me enjoy your collection this summer. Had a blast in Montana.
Old 11-11-2016, 01:11:29 AM
Nathan K. Nathan K. is offline
Default Re: I Got This Big Box Monday----
Nice one Skip,
Now I see why you bought a single cylinder- too display with the twin(or was it the other way?). look forward to seeing it running!.
Nathan.
Old 11-11-2016, 11:11:04 AM
HBurk HBurk is offline
Skip,
I don't see any damage to that box. How do you explain how it got damaged?
Monday morning wakeup. sftyvlv1 Steam Stationary Engines, Traction Engines, Steam Boats 10 09-16-2015 09:23:36 PM
Ed is going to be on pickers monday Ronald E. McClellan Antique Gas Engine Discussion 4 03-20-2011 11:49:07 PM
Went to see more engines last monday.. Ron Davis Antique Gas Engine Discussion 12 09-12-2010 09:05:11 PM
