onan 7.5 MDJE needs help
this thread has 35 replies and has been viewed 3928 times
Old 03-20-2014, 11:04:26 AM
blaise805 blaise805 is offline
Default onan 7.5 MDJE needs help
Hi new guy here could use some help. I have the 7.5 MDJE generator serial number 1269187916. The generator has seized and is mounted under the floor in the galley of an old boat. I would like to know first of all are rebuild parts available for the engine. There are no manuals on board so I will need to find some way to get the specs. The second thing is can I remove the engine from the electric plant without taking the entire unit while in place. I think it would almost impossible to remove it as a complete unit. I have everything ready to come out but would like some insight. Thanks for any help in advance.
Old 03-20-2014, 11:19:23 AM
Kevin K Kevin K is offline
Default Re: onan 7.5 MDJE needs help
Your generator was made in December of 1969. If you post the complete model number, and an email address that can accept large attachments, we can send some manuals your way.
Old 03-20-2014, 11:24:45 AM
Ted_Cool Ted_Cool is offline
1: Can usually be fixed. Parts are getting hard to find, but you're at the right place.
2: Separating the genset while in the hold would not be my choice. I'd rather rebuild the decking if necessary. How was it installed to begin with?
Old 03-20-2014, 11:30:48 AM
Billy J Shafer's Avatar
Spent many hours cussing out boat builders.Unless you can find a way you will have to remove it in pieces.Done that many times and it is not fun. Parts are out there you just have to look.
Most of the time. The idiots put the generator in the worst place they can find. Then build the boat around it.
The Following 2 Users Say Thank You to Billy J Shafer For This Post:
Old 03-20-2014, 12:53:58 PM
Kpack
Does the gen have a lot of hrs ? Could be a piston stuck at the top.
When you post a email for the manuals let us know the part numbers you need.
S&r sales and some others have old new stock but its pretty high if you find it.
Old 03-20-2014, 01:07:19 PM
Thanks for the quick replies here is another set of numbers 3cr/z2688 I'm not sure what I will need yet. To remove the unit out in one piece would be very difficult. I think damn near impossible without tearing up the inside of a beautiful boat so if I can remove the engine that's do able. The generator was working fine and the owner went to start it next trip and no go. I take care of the machinery for him and its locked up solid.
Old 03-20-2014, 01:20:05 PM
Kpack
If you could get to the top of the piston to see if its stuck on the ridge it would help.
You can take a 2x4 and hit the piston and knock it loose but your taking a chance if its still hooked to the crank.
If it were mine and a 69 model and it was that hard to get too I would by a new 1800 unit if that much stuff has got to be torn out.
Old 03-20-2014, 02:28:38 PM
possibly hydrolocked by water getting in past the vacuum break on the exhaust.
Could try pulling the injectors and spinning by hand with a socket on the end of the crank to see if water comes out. At least you might find out why it's locked up and develop a plan from there.
As Billy said. Most gensets in boats are put in places where they are damned near impossible to work on them.
You will lean many new curse words working on boats as you lean down through small scuttle hatches at arms length.
Old 03-20-2014, 09:43:22 PM
Yes I'm well versed working on boats I ran dive boats for years in the channel islands off California. I tried to turn the crank but no luck. I think if I can see a manual and separate the engine I could get that out and rebuild it if possible.
Old 03-20-2014, 10:34:23 PM
I would pull the injectors (as Ed said) and valve covers before u decide to pull it all apart.. start simple and go from there... maybe a stuck valve or you have water in the cylinder or something else that could be a easier fix.... was it running when it locked up or did it sit for awhile?
Worst case scenario... Your in luck.. im about an hour from Oxnard.., actually use to live in Port hueneme and happen to know where 4 of your generators are if you need any parts or a complete engine or etc... they were pulled from 2 yachts being overhauled a few years ago and have had a nice resting place stored inside.. all were runners when removed and I think one only has 400 ish hours..
The Following 2 Users Say Thank You to YellowLister For This Post:
Onan MDJB or MDJE? Nazrat Onan Generators 24 08-28-2011 05:21:12 PM
Onan MDJE 6-7.5KW Help Mainshiptom Onan Generators 4 04-19-2010 05:32:50 PM
7.5 KW Onan MDJE won't crank bayoucadillac Onan Generators 12 02-20-2010 03:44:53 PM
Onan 7.5 MDJE - 3CR Help LarryGlover Onan Generators 11 07-19-2007 04:38:12 PM
Onan MDJE 6-7.5KW Help Mainshiptom Onan Generators 0 09-28-2005 05:48:23 AM
