Steam Engines
Ames Iron Works Steam Engine
this thread has 9 replies and has been viewed 2312 times
Old 05-30-2015, 11:17:19 PM
Sean Keys Sean Keys is offline
Default Ames Iron Works Steam Engine
Today I picked up a Ames steam engine at an auction. It is serial number 374 and has a 7x8 bore and stroke which I believe makes it a 15 horse engine. It is a wonderfully intact and complete engine right down to its original shipping skid with labels still attached but unreadable and sub-base (pictures to come tomorrow) I was wondering of I could get some help narrowing it down to an aproximate year. From what I gather Ames started in 1854 and being that it's a pretty early serial number would that make it pre civil war??
Old 05-31-2015, 08:14:24 AM
Glenn Gieszler Glenn Gieszler is offline
Default Re: Ames Iron Works Steam Engine
It sounds like you may have a vim automatic engine (governor in the flywheel), 7x8 is the smallest one build that I have listed it is rated between 16-18 hp, if it is a throttling type (steam governor mounted on the steam chest) then it is rated at 10hp, these engines do not have a reverse feature they were build to run over or under as desired by the purchaser, the serial number tag and location will be of interest to others owners on here, so do post a picture. These engines were more than likely starting to be built in the 1890's and are not as old as the company as they started transitioning out of agriculture equipment and more into commercial boilers, industrial and electrical generation
Last edited by Glenn Gieszler; 05-31-2015 at 09:34:45 AM. Reason: Add more information
Old 05-31-2015, 11:30:25 AM
Here are the photos. I did notice that there is a 15 stamped on top of the cylinder.
ID:	226630   Click image for larger version
ID:	226631   Click image for larger version
ID:	226632   Click image for larger version
The Following User Says Thank You to Sean Keys For This Post:
Old 05-31-2015, 11:33:28 AM
I didn't see a serial number tag on it anywhere. Just a tag that's from general machinery out of Philadelphia.
Old 05-31-2015, 11:54:46 AM
Cute little bugger and in nice shape, excellent purchase, not sure what the 15 means
Old 05-31-2015, 01:00:20 PM
Thanks for that photo! That's good info! Is it still from the 1890's or is it possibly earlier than that?
Old 05-31-2015, 01:22:26 PM
I have not found yet any serial number info, but with all the catalogs and information on this company that i have I would be confident I saying that the earliest that they may have made was around 1890 there is one catalog that I know of that reported to be from 1887, as I have not seen it yet I cannot be sure as the the exact date they were made, I know they were not shown in catalogs from 1885 and earlier
Old 06-01-2015, 01:28:44 PM
Batch33's Avatar
Batch33 Batch33 is offline
I would agree with Glen , I have a 10x12 ames and I always considered it a later engine , teens to early twenties . Ames was located in Oswego N.Y, down near the lake .
The oiler on the left main bearing cap ,is that threaded into the cap or is there some type of putty there ? If possible could you take a picture of your serial number location , I can not find one on my engine anywhere .
nice engine though , I like the oiler stand for the eccentric , mine is missing so I wondered what the correct one would look like .
Old 06-01-2015, 04:36:59 PM
Jim Mead Jim Mead is offline
Nice one! "Little" maybe, but still heavy. We'd be loading something and my Dad would say, "why don't you collect stamps?". I'm beginning to understand what he meant 45 years ago.....
Old 06-01-2015, 04:54:15 PM
That oiler base is either just a press fit or threaded. My serial number is on the flywheel side of the crank.
Vulcan Iron Works Steam Shovel J D Martin Steam Stationary Engines, Traction Engines 16 11-01-2013 11:15:57 PM
Erie City Iron Works Steam Engine Alan James Steam Stationary Engines, Traction Engines 6 04-28-2010 01:56:31 PM
Ames Iron Works Peter Hahn Steam Stationary Engines, Traction Engines 1 10-02-2003 01:18:24 AM
Ames Iron Works engine John Bunting Steam Stationary Engines, Traction Engines 10 05-05-2003 08:22:14 PM
Ames Iron Works John Bunting Antique Engine Archives 0 08-09-2002 07:59:22 AM
