Onan Gen Shutdown
this thread has 23 replies and has been viewed 3040 times
Old 02-11-2014, 12:25:14 AM
mech1369dlw mech1369dlw is offline
Default Onan Gen Shutdown
I have read a few times about not letting the generator shut down while under load by running out of gas. Why? What happens that is so bad about this happening? just curious. Thanx
Old 02-11-2014, 12:34:53 AM
Jim Marcozzi Jim Marcozzi is offline
Default Re: Onan Gen Shutdown
It can:
Kill the residual magnetism that's required to start generation
Overload the regulator since it will go full field to try to compensate for low output
Damage the load due to spikes, low voltage or incorrect frequency
I'm sure others will add
Old 02-11-2014, 08:36:25 AM
In addition to the possibilities Jim mentions, add "considerably lighten one's wallet".
Old 02-11-2014, 10:06:19 AM
Billy J Shafer's Avatar
The older ones with out regulators are not effected as much as the ones with them. It doesn't always damage them. But you want to avoid a loaded shut down as much as you can. Don't need to see the magic smoke come out.
Old 02-11-2014, 10:34:48 AM
Leon N. Leon N. is offline
Shutting down a Magneciter designed generator under load will not damage this style generator but it may do harm to the connected loads. Just not a good idea to abuse your refrigerator compressor or even the TV. As mentioned already, it may damage the later designed Onan voltage regulator controlled generators.
Nevertheless, back in 1970 I designed and successfully installed my own version of a generator shunt trip device for the very reasons mentioned above. There are all kinds of so called shunt trip devices. However, mine monitors the generators frequency. When the frequency is within spec limit, + or - 3 hertz, a contactor closes there by making the 120/240 output available. The circuit is also damped to prevent nuisance tripping.
Leon
Old 02-11-2014, 10:42:15 AM
They call that roll off protection now of days Leon. Sure saves some money
Old 02-11-2014, 04:27:10 PM
Isaac-1 Isaac-1 is offline
Thanks for bringing up this topic, it reminded me that I had a 200 amp shunt trip molded case breaker laying around, maybe I will use it to build a safety out of range (high / low voltage or frequency) trip for my MEP-003a since they tend to go high voltage on AVR failure.
Old 02-11-2014, 05:04:51 PM
scoops scoops is offline
Leon
I'd be more interested in what you built Leon.
Care to share how it was constructed?
Old 02-11-2014, 05:13:57 PM
Scoops, yes think I can assemble some information. I am not a computer wiz, but I will see what I can do.
Old 02-11-2014, 05:32:27 PM
grif grif is offline
Is that schematic from the Radio Amature Handbook for a voltage controlled trip using a GFI still floating around here?
ONAN NHE shutdown while running Ray Armstrong Onan Generators 8 09-16-2013 01:28:10 PM
need help with Onan RDJF 17.5 overtemp shutdown ollie Onan Generators 7 07-25-2012 03:04:50 PM
Onan MDJA shutdown Mod. Daverepair Onan Generators 1 04-28-2012 09:43:37 PM
Onan Shutdown Circuit won't allow Start Robert Ward Onan Generators 8 06-15-2011 12:08:06 PM
Onan 7.5JB: Add low oil pressure shutdown? ChadS Onan Generators 14 04-28-2005 10:34:32 AM
