It happens to the best of us... Auto choke
this thread has 2 replies and has been viewed 1174 times
Old 02-19-2014, 04:21:08 PM
Heliarc Heliarc is offline
Default It happens to the best of us... Auto choke
Today I was working on installing a new float on my Onan. I believe it's an L series. #205LK1.
I couldn't get the exact float but I got one close that my parts guy believes is from a Kohler. I had to swap the retainer that holds the float to the carb but I got it in place and it works nice.
A while ago I had removed the automatic choke control but I figured I'd give it another go. Then I can just hit the starter and walk away instead of manually choking while it's raining or whatever. I put it on and the engine was still warm. It fired up fine and I noticed the choke which was fully open had started bouncing and then went fully closed. It took me a few minutes and then I realized when I took it apart to get it back on I must have put the spring in backwards I reversed the spring and now it works just fine.
The Following 3 Users Say Thank You to Heliarc For This Post:
Old 02-19-2014, 05:01:33 PM
Onan Dan's Avatar
Onan Dan Onan Dan is offline
Default Re: It happens to the best of us... Auto choke
Ye I did done the same thing on my BFA 4.0 running the choke went shut reversed the spring and back in business.
Old 02-19-2014, 05:30:52 PM
Billy J Shafer's Avatar
I have been working on Onan's since 1980. I still have problems with that spring.
The Following 2 Users Say Thank You to Billy J Shafer For This Post:
The NEW Briggs Auto Choke System - Problems, HELP? Briggs Man Garden Tractors / Mowers / Scooters 26 07-15-2015 03:50:17 PM
IHC LB choke Butch50 Farm + Industrial Antiques and Collectibles 2 02-27-2013 04:16:51 PM
Ihc LB 1 1/2- 2 1/2 Choke Pin ?? ssg57 Antique Gas Engine Discussion 1 02-21-2013 08:03:57 AM
Onan 6.5 nh-3cr/12014d no auto choke mech and low voltage froggy4873 Onan Generators 6 08-09-2012 02:16:19 PM
choke cable Mark Willerick Garden Tractors / Mowers / Scooters 2 01-02-2007 03:54:26 PM
