this thread has 4207 replies and has been viewed 277203 times
Old 02-03-2013, 06:09:47 PM
Default Re: What have you done to your Onan generator today?
[QUOTE=Ed Sparks;873516]I have an old set of gasket punches for cutting bolt holes out, that came from my grandfathers tool collection.
QUOTE]
I have many tools from my Great Uncle, he was a machinist, & taught me a lot about sitting back & “figuring” things out. I am proud every time I pick up one of his tools. There are sets of Craftsmen wrenches right beside the old ones he used, but I use his old ones first most of the time.
The Following 3 Users Say Thank You to Max Thompson For This Post:
Old 02-03-2013, 06:43:24 PM
len k len k is offline
For making gaskets a real scalpal works wonders, they are available as industrial item. Handles much better than an Exacto knife (whick rolls arround in your hand). Instead of dragging it to make a cut, I just press it into material , then out and advance and press again. Works well for circles, edge is a series of short straight sections. Takes awhile but comes out nice.
My scalpal is a "Feather" brand #4, I use a #25 blade by "B-P"
  #63
Old 02-03-2013, 06:52:53 PM
Onan Dan's Avatar
Onan Dan Onan Dan is offline
Thanks everyone for the good ways in which to make gaskets. now i know what i will be doing this week can,t wait to make up some. i did cut out my manifold gaskets last month and i tell ya they look factory.lol
oh my hole puncher is one of my wifes paper hole punchers just the right size dia, lol she never missed it yet..
Old 02-03-2013, 09:08:18 PM
I make hole punches from pipe nipples. Grind the end off at a tapper until it is sharp. Works great for 1/8" & up.
  #65
Old 02-03-2013, 09:28:51 PM
Kpack
I got all my 4ky back together and took a battery out of the trailer to try it starter was just clicking checked battery it was dead my daughter ran it down yesterday so I tried to jump it now I'm getting a fault code so I just gave that gen a 1 finger fault code back
  #66
Old 02-03-2013, 09:51:16 PM
Motorhead's Avatar
Originally Posted by davp View Post
The air temp. rose above 32 degrees today, so I thought I'd spend some time with the 5.0 CCK. I have'nt had time to do anything with it since I picked it up until now.
The plan was to degrease everything, perform a complete tune up, points, plugs, condensor, new plug wires, clean the carb., clean the gas tank, replace the fuel line, and filter.
Things did'nt quite work out though. I picked up the wrong diameter fuel line and filter. Onan also sent what turned out to be two different spark plugs, one having a long shaft, the other one short. I left the old plugs in for now.
I did'nt want to run the engine with the old dirty fuel filter in place after cleaning the carb., so I just pushed it back into the garage.
Looks like I need to spend a little more time with the old girl.
MAN...I like your tractor!!!
Old 02-03-2013, 09:59:50 PM
Onan Dan's Avatar
Smile Re: What have you done to your Onan generator today?
Thanks Max never thought of using pipe nipples .
The Following User Says Thank You to Onan Dan For This Post:
  #68
Old 02-04-2013, 09:40:17 AM
Lawdawg Lawdawg is offline
Stainless Steel Tubing in Assorted Sizes make Excellent Hole Punches. Rattail File on the inside with large amounts of Elbow Grease will Sharpen them Nicely. Doug.
Old 02-05-2013, 05:01:09 PM
Xeonpony Xeonpony is offline
Just got the remote start all hooked up and further hacked my noma battery back up pannel to hold the buttons
I just hope the lables come out as good as they do in my paint test picture lol
ID:	157198   Click image for larger version
ID:	157199   Click image for larger version
Name:	Control pannel labled.jpg
ID:	157200   Click image for larger version
Old 02-05-2013, 05:36:02 PM
grif grif is offline
you know,,, of all the one off goofy little things,,, having a metal lathe set up makes stuff like this trivial. Don't know how many quick little things like that I've made. bushings for my brotherinlaw's front loader,,, pins for same,,, air adaptor for a friends fly fishing float tube,,, all just eyeball and a quick hack on something quick from the junk box. hole punches are really quick. Turn the outside of some random (easy machining) bar stock to the diameter of the hole, (unless you have a pipe nipple ;-) then a chamfered edge/hole in the end. I've had good luck using end grain 2x4 pine as backing. Seems to "cut in" and support the gasket material quite well. being able to put the chamfer on the inside edge seems to work better for me.
Love that thing ;-) If I was younger I'd change jobs and start as a machinist helper ;-)
---------- Post added at 01:36 PM ---------- Previous post was at 01:34 PM ----------
Looked at the new regulator box,,, and layed hands on the 15JC this morning getting in the truck to go to work.
Soon,,, 1/2 done with the texture and tape in the new mancave.
The Following 2 Users Say Thank You to grif For This Post:
