How many obsolete thread counts were used?
this thread has 14 replies and has been viewed 9915 times
Old 09-17-2004, 08:16:57 PM
Pat Barrett Pat Barrett is online now
Default How many obsolete thread counts were used?
Last night I asked about obosolete wrench sizes, Tonight: How many obsolete thread counts were used on some of our old stuff? I know, of 3
Old 09-17-2004, 08:48:50 PM
Junkologist
Default Re: Fri. Nite Trivia
I have a Standard Pump Engine where the threaded crankshaft ends are 1" and 12 threads per inch. I had to have the nuts custom made.
Mike
Old 09-17-2004, 08:59:46 PM
Simon, Scotland UK.
UNF(unified national fine), UNC(unified national coarse), BSF(British standard fine), Whitworth, to name but a few.
Regards
Simon
Old 09-17-2004, 09:24:03 PM
Great, you got one of the 3, I had in mind
Old 09-17-2004, 09:39:09 PM
Roland Finkenbinder
The Sta-Rites that I have worked on have 1/2-12 threads on the head studs.
Old 09-17-2004, 10:11:31 PM
Ironman
I have run across a 3/8-26 thread on some needle valves.
Old 09-17-2004, 10:19:40 PM
The 1"-12 & the 1/2-12 are two of the 3 I have encountered. 1/4'-24 is another, Anyone had to try and find a nut for the moveable end of an E.K. is is odd too.
Old 09-17-2004, 10:30:45 PM
Chip Watford
Pat,I too have run into the 1/4-24 thread on the Wico trip.Mcmaster-Carr sells taps and dies for this thread as well as other obsolete ones.They are listed as National Special Threads. Chip
Old 09-17-2004, 11:01:21 PM
Rudy
The two oddest threads i have encountered are 11/16-11 threads per inch which i threaded on valves and nuts on an IHC 20 H.P Famous tractor and # 12-24 machine screw which holds magnets onto a Bosch AB-33 mag.
Old 09-17-2004, 11:04:53 PM
Eugene Borsoff
The igniter parts on early Foos engines were threaded similar to 3/4" pipe thread as they have a tapered thread but they were 12 TPI not 14 TPI. Prior to WWI manufacturers would tread whatever they wanted. The United States Govenrment during WWI established SAE standard sizes and TPI to insure interchangable bolts and nuts.
Difference between Thread Restorer....Rethreader...and Thread Chaser??? packrat56 Antique Gas Engine Discussion 12 07-31-2007 12:59:11 PM
Off topic: Obsolete Chevy parts Al Wait Antique Autos and Trucks 1 10-14-2006 07:21:01 PM
Obsolete brake hardware Dick Welty Antique Engine Archives 6 10-19-2004 12:54:40 AM
Obsolete Water Pump Parts needed Bob Naske Antique Engine Archives 6 09-28-2004 05:31:46 PM
Supplier for obsolete brushes Harvey Teal Generators & Electric Motors General Discussion 12 07-16-2002 12:06:40 AM
