Fairbanks Morse 739 Questions
this thread has 6 replies and has been viewed 1211 times
Old 06-22-2018, 01:19:01 PM
AKMark AKMark is offline
Default Fairbanks Morse 739 Questions
I just picked up this awesome engine and it runs perfect on gasoline, I would like to run it on propane. The valve on the front I assume is for adjusting the flow, what is the brass elbow on the back side for. It looks like it's plugged off right now. I think it was made in the 50s but I'm not sure.
Thanks
Mark
ID:	312869   Click image for larger version
ID:	312870   Click image for larger version
Old 06-25-2018, 07:24:20 AM
edward moller edward moller is offline
Default Re: Fairbanks Morse 739 Questions
that was the fuel pickup, there is a diaphram under the round cover, that is a fuel pump
The Following User Says Thank You to edward moller For This Post:
Old 06-25-2018, 10:10:07 AM
Thank You, it's gravity fed now so I can leave it the way it is. I will hook up a propane tank and give it a try.
Mark
Old 06-30-2018, 10:42:43 PM
Reed Engine's Avatar
Those metering valves aren’t the best. A Hayes gas clock or similar work far better to regulate the gas. Most people start them on gasoline just a squirt or two into the butterfly. Then as it’s dying open the valve slowly till it hits on the propane.
The Following User Says Thank You to Reed Engine For This Post:
Old 06-30-2018, 11:56:02 PM
Originally Posted by Reed Engine View Post
Those metering valves arenít the best. A Hayes gas clock or similar work far better to regulate the gas. Most people start them on gasoline just a squirt or two into the butterfly. Then as itís dying open the valve slowly till it hits on the propane.
Thanks I had it running on propane yesterday. I did start in on gasoline and switched it over. I will look into the valve you mentioned.
Mark
The Following User Says Thank You to AKMark For This Post:
Old 08-19-2018, 10:12:41 AM
Allan Wright Allan Wright is offline
My most favorite engine. The pictures donít really show how big these things are.
They have a one of a kind sound when theyíre running.
Old 08-19-2018, 10:50:28 AM
I have it at the Tillamook show right now, everyone comments about the sound
3hp Fairbanks Morse Z Questions Jordan Antique Gas Engine Discussion 14 08-17-2015 09:24:55 AM
2HP Fairbanks Morse Questions gliebegott Antique Gas Engine Discussion 5 03-08-2010 12:42:09 PM
Fairbanks Morse ZC-503 and ZC-346 Questions Christian Berlin Antique Gas Engine Discussion 14 10-26-2009 11:58:50 PM
Fairbanks Morse Z 3hp questions Zira Magnetos, Ignition Coils and Spark Plugs 2 02-14-2009 04:52:24 PM
Questions on Fairbanks Morse Shine Stringer Antique Gas Engine Discussion 10 10-03-2007 02:38:16 AM
