runaway shutoff valve?
this thread has 2 replies and has been viewed 1632 times
Old 12-30-2011, 12:40:34 AM
asandberg6 asandberg6 is offline
Default runaway shutoff valve?
Anyone ever install a ball valve on a turbo oil feed line? Seems to me this would be a good safety feature for those cases where a bad seal feeds an engine hot lube oil.
Old 12-30-2011, 04:33:33 AM
pjjms pjjms is offline
Default Re: runaway shutoff valve?
I suspect the turbo would suffer a fair bit shutting down this way making it an expensive day. Blocking the air intake is an effective way to stop the engine.
Old 12-30-2011, 12:07:34 PM
cornbinder89 cornbinder89 is offline
By the time the engine is running away on engine oil, there will be a fair bit in the intake. shutting off the turbo feed will be like closeing the barn door after the horse is out. Also with the turbo spinning at speed 100,000 rpm+ and no oil bad things will happen.
A board over the intake is the safest, or a CO-2 extingusher ( NOT DRY CHEM!!!)
The Following User Says Thank You to cornbinder89 For This Post:
1944 Murphy ME-650 runaway Bill Bonyun Vintage Diesel and Oil Engines 10 08-30-2011 09:48:47 PM
DD 3-53 runaway question -- does flapper valve always stop the engine? ichudov Vintage Diesel and Oil Engines 31 06-27-2011 09:16:46 AM
Fuel Shutoff Leaking at Tank Waterlogged Generac Generators (SEARS, etc.) 7 12-25-2009 08:22:26 AM
Runaway Steamroller Rolls Over survivingworldsteam Steam Stationary Engines, Traction Engines, Steam Boats 12 08-20-2006 01:26:44 AM
Runaway Fairbanks Gene Fisher Antique Gas Engine Discussion 10 11-03-2005 06:01:59 PM
