New Onan voltage codes
this thread has 3 replies and has been viewed 12818 times
Old 04-30-2013, 03:14:38 AM
GHanners GHanners is offline
Default New Onan voltage codes
I also found this I havnet seen
if anyone wants to move in the stickies I don't care
The Following 6 Users Say Thank You to GHanners For This Post:
Old 04-30-2013, 08:59:23 AM
Kevin K Kevin K is offline
Default Re: New voltage codes
Thanks. For convenience, I converted this to a pdf file.
The Following 4 Users Say Thank You to Kevin K For This Post:
Old 04-30-2013, 10:02:19 AM
Kpack
You men are good now all I have to do is figure out all those numbers
Old 05-01-2013, 03:12:49 PM
just a note from what i've seen
the old codes were 3cr for example =120/240 4 wire with R behind for stationary- electric start-remote
the new ones are like dkdfj (dkd model) F is stationary-remote-electric start then the voltage code J
backwards of the old format
New Onan fault codes? Cat Man Onan Generators 12 05-28-2013 03:36:02 PM
Onan CCK date codes? Motorhead Onan Generators 4 04-07-2013 07:21:55 PM
Onan Generator 150JC-18R/16894AB Some Voltage but Low Voltage johannes Onan Generators 6 01-03-2013 06:06:06 PM
Onan Option Codes MBB Onan Generators 4 05-12-2011 11:31:03 PM
Onan Model ID + Voltage Codes OnanParts Onan Generators 5 01-31-2011 04:39:49 AM
