Onan starters parts and interchange
this thread has 2 replies and has been viewed 17016 times
Old 07-13-2014, 07:00:56 PM
GHanners GHanners is offline
Default Onan starters parts and interchange
Several have ask for starter info and I' posted it in the past and I had to search to find it can someone make this a sticky ?
1st prestolite
Id it has a cast nose with a bushing on the end in front of the starter drive
also most have prestolite tag with MEO 6003
lester part #'s
starter # 191-0324 is lester # 5097 is a prestolite MEO 6003
solenoid for the prestolite accumax 10-ch965
starter drive accumax 11a-p1818
onan new gear reduction starter 191-1398 use 191-1399 need Onan 191-1400 starter mount to use
Mitsubishi M2T55971 & M2T53481 model #'s
Lester No: 18168
LESTER 5097
Type STARTER
Mfr PRESTOLITE
Voltage 12
Rotation CCW
Teeth 10
Str Type DD
Short Note
ONAN & THERMO KING MARINE, ETC.
NOTE: CAN BE REPLACED WITH 103-073, IF ONAN PLATE 191-1400 IS USED
INTERCHANGES
ACCUMAX N/A
ACE TRI-STAR CM5097N
AIM SQ-0021R
ALLTECH 105-5097
ANDRE NIERMANN 016003
API MARINE ST6003
ARCO MARINE 50166
BEPCO 80-5097
BOSTON AUTO 3160-160
COSMOS 90-5097
DIXIE TS-5062
DIXIE NEW 205-18102
DUBOIS N/A
EGI S-5097
ELPAR 013103601
J & N 410-20000R
NASTRA R&R ONLY
ONAN 191-0324
PRESTOLITE 46-185, 46-863, MEO6003
QUALITY 5097
RAYLOC 44-0228
ROMAINE ELECTRIC 41-5097
STRATOLINE 80-5097
TECHNO CVC IND-2256003
THERMO KING 44-4731
TSA 5097N
WHATCOM 45114
WILSON HD 91-06-1885
ZORKOS 5097
PARTS BREAKDOWN (lester P/N's)
ARMATURE 5060-2272
BRUSH (GRD)5460-6014
BRUSH (POS)5460-6016
BRUSH HOLDER 5560-6505
BUSHING 6-15914
CASTING D.E. 5660-6099
DRIVE 6160-1818, 6160-P1818
FIELD COIL 5260-114
PLUNGER 6760-004
SHIFT LEVER 6860-601
SOLENOID 6660-003
SPRING - SOLENOID 9460-6501
APPLICATIONS
ONAN Marine
ENGINES DJ-60 1960-1976
ENGINES DJC 1960-1976
ENGINES JC
ENGINES RJC 1969-1980
ONAN OPE, Marine & Ag & Industrial
Engines DJ-60 1960-1976
Engines DJC 1960-1976
Engines JC 1975
Engines RJC 1969-1988
ONAN Outdoor Power Equip.
ENGINES JC
ENGINES RJC 1969-1988
2nd is the Mitsubishi starter it has an alu nose with no bearing support in front of the starter drive
NOTE prestolite plate can me modified to fit mitsubishi the mitsubishi plate has holes for both
Lester No: 18168
LESTER 18168 / PIC # 103-073
Type
STARTER
Mfr
MITSUBISHI
Voltage
12
Rotation
CCW
Teeth
10
Str Type
OSGR
Short Note
POWER GENERATOR WITH ONAN ENGINE
INTERCHANGES
ACE TRI-STAR
CM18168N
AIM
SC-0056R
ALLTECH
124-18168
ANDRE NIERMANN
013481
API MARINE
ST1398, ST6003NK
ARROWHEAD
SMT0183
BEPCO
80-18168
BOSTON AUTO
3103-073
COSMOS
90-18168
DIXIE
S-8620
DUBOIS
M900431
EGI
S-18168
ELPAR
012503658
MES MOTORCYCLE & MARINE
18168N
MINNPAR
57-3135
MITSUBISHI
M2T55971
MITSUBISHI SALES
M2T55971
NASTRA
18168
ONAN
191-1399
QUALITY
18168
REMY SMALL MOTOR
RS41175
ROMAINE ELECTRIC
18168N, 18168N-OEM, 41-18168
STRATOLINE
80-18168
TECHNO CVC
IND-2845972
TSA
18168N
WAI
18168N
WAI (OLD)
2-2093-MI
WHATCOM
42421
WILSON HD
91-27-3151
ZORKOS
18168
PARTS BREAKDOWN
ARMATURE
5003-2890
BEARING
5-2603, 5-3203
BRUSH
5403-2706
BRUSH HOLDER
5503-039
SOLENOID CAP
6703-341
APPLICATIONS
ONAN Marine
ENGINES DJC
ENGINES RDJC
ENGINES RDJF
Engines DJC 1979
Engines RDJC 1979
Engines RDJF 1979
ENGINES DJC
ENGINES RDJC
ENGINES RDJF
The Following 8 Users Say Thank You to GHanners For This Post:
Old 10-23-2016, 03:34:59 PM
jbv41 jbv41 is offline
Default Re: Onan starters parts and interchange
Does anyone know what Kohler Engine is used in the 4.0 BFA Onan genset?
Old 08-25-2017, 04:19:03 PM
mightytravis mightytravis is offline
Hi,
Thanks for the info. I am hoping to get some clarification. From what I'm reading, my starter is the one with the cast bit, making it the PrestoLite, with the solenoid for the prestolite accumax 10-ch965. I'm attaching the picture of my 60s era DJB (I think, unfortunately I pick it up a few years ago no tags, plates or serials of any kind visible)
If anyone can confirm that this is the correct model of solenoid, I would sure appreciate it. I've already purchased the wrong one a couple of times.
Thank you.
ID:	289413   Click image for larger version
ONAN part #510-0099 bearing interchange? F. Moore Onan Generators 11 01-28-2014 12:37:30 PM
IHC Parts interchange a jossund Antique Gas Engine Discussion 0 12-29-2013 11:34:11 AM
Onan AJ 2.5 Piston interchange with Briggs a31ford Onan Generators 3 06-29-2012 03:48:05 PM
Briggs parts interchange not in Briggs book Ken Karrow Small Air Cooled Gasoline Engines 4 09-17-2011 12:50:16 AM
Handy Andy and Bluffton parts interchange? Shelby Babcock Antique Gas Engine Discussion 2 04-19-2009 08:42:42 PM
