Onan 10JWC-3E Found a New Home
this thread has 15 replies and has been viewed 1196 times
Old 10-02-2016, 03:31:08 PM
Charlie Foxtrot Charlie Foxtrot is offline
Default Onan 10JWC-3E Found a New Home
Found in a barn. looks intact. will post updates.
ID:	264451   Click image for larger version
The Following 3 Users Say Thank You to Charlie Foxtrot For This Post:
Old 10-02-2016, 05:26:12 PM
Handyhiker1 Handyhiker1 is offline
Default Re: 10JWC-3E found a new home
Looks cool!! Nice find.
Old 10-02-2016, 09:26:57 PM
Default Re: Onan 10JWC-3E found a new home
All threaded fasteners presently soaking in ATF w/solvent. Reportedly this was in-service & run-able when removed & relocated to a rural barn. Has a 6' whip of modern liquid-tight w/#6 THHN still attached. Ammeter glass broken & top rad tank damaged (looks like a bucket from a loader creased it while relocating it). Barn owner bought it for the jeep engine. Ended up not needing the engine so it sat. Clean up day came & I got lucky. Wasn't looking for genset but rather an older CJ jeep to rebuild/refurb for grand daughter.
Old 10-02-2016, 11:41:27 PM
Hopefully you do not split it up.. that is much less.common than a jeep..
Old 10-03-2016, 09:47:29 AM
HBSaunders HBSaunders is offline
got a similar one with jeep engine but a 42 vintage. runs well , as some earlier have said is a gas hog, howard
Old 10-03-2016, 10:31:24 AM
Dale Russell Dale Russell is offline
Question Re: Onan 10JWC-3E found a new home
Just wondering, Would that be a PE 98? I was in Japan in 52 & 53 where we used a Generator for Power for our Meteorology Equipment that was a PE 98. Seems like it had a 4 Cyl. engine like a Jeep. Dale
Old 10-03-2016, 04:03:29 PM
Unknown model
Engine Generator Set data plate states model no. 10JWC-3E, Spec 305A, Contract No. DA 36-109-ENG.3516
Gasoline Engine H.P. 32 at 1800 R.P.M. 4 Cycle,
MF'RS. Type 805.750 Manufacturer Willys Overland Motors, Inc
Generator Model No. 10JWC/46, A.C. Volts 125/250 K.W. 10 P.F. 0.8 Amperes 50 Phase 1 Cycles 60 Conrt Duty 40*C Rise R.P.M 1800
Willys Jeep L134 engine, 6 Volt generator & starter, Magneto ignition system
Finishing up an annual on small AC, then oil change tonight, 6 volt battery, load bank on the output mains & test fire.
Old 10-03-2016, 05:47:18 PM
Motorhead's Avatar
Remember these old Jeep engines were about 5 to 1, maybe 6 to 1 compression ratio. No wonder they weren't fuel efficient..... But they ran about forever. Nice score. That is a nice survivor, I'd just clean it up and check it out good and run it.
My 1939 WILLYS Pickup.
Bought in 1971
Old 10-03-2016, 09:50:01 PM
My intention is to not split it up. It was a working generator when it was pulled & relocated to a barn.
As promised, I finished the annual on the CTSW, pushed it out of the hangar and off to it's owner. Walked over to sleeping beauty, grabbed a rag, pulled the dipstick, nuthin' showin'. Poured in some dino juice, grabbed a golf cart battery & jumper cables and hooked it up. Turned the key, heard a click (the voltage regulator) and pushed the starter button. Just a little sizzle & crackle - the battery needs a charge. Charger cooking, grabbed a diet soda, and clickety-clack on the key board. Update to follow.
Two pops later & I couldn't wait any longer. Jumped it off of an old Benz sitting next to it. Got 90 degrees of rotation before the battery gave up (won't overcome the compression). Will charge overnight, pull plugs and rock the crank some more while giving it some ATF from above. BTW it rolled about 90 degrees by hand before I gave it a try w/battery.
The Following User Says Thank You to Charlie Foxtrot For This Post:
Old 10-05-2016, 09:42:17 PM
Pulled the plugs, removed the radiator (drained coolant - still green), squirted some atf in the cylinders & slipped a socket on the crankshaft nut. I can roll the crank 540 degrees rotation then it stops (cw & ccw). It feels like something is trapped in the bell housing or between the armature & winding's. Contemplating splitting the gen from the engine. Can anyone point me towards a manual for this thing? Thanks in advance.
1953 Onan Mod 10JWC-3E Generator preperations Crosshair Onan Generators 21 07-24-2014 03:17:54 PM
1953 Onan Mod 10JWC-3E Generator, good buy? Crosshair Onan Generators 5 04-06-2014 02:50:06 PM
A treasure found in my home town made in my home town lil herc Antique Marine Engines and Outboard Motors 19 01-25-2010 03:09:27 AM
Onan 10JWC-1R 110HQ-3R8/14F Army genset bkahler Onan Generators 16 08-30-2007 10:24:22 PM
Onan 10JWC-1R Army genset - photo mixup bkahler Onan Generators 0 06-29-2007 10:06:22 PM
