Onan 6.5 MDKDP26501C output 177 Volts instead of 220
this thread has 14 replies and has been viewed 1107 times
Old 03-18-2017, 08:25:55 PM
Harry's Avatar
Images: 312
Default Onan 6.5 MDKDP26501C output 177 Volts instead of 220
Originally Posted by skip to joy
hello Harry, first i want to say hello, i am new here and my name is roman... thank you for this informative page. I am sorry for my English. I am from Austria and sometimes use a translator.. i hope everything is to understand for you.
the reason for my visit was because of searching for a wiring diagram for my generator (onan 6,5 MDKDP26501C). i use him in a formosa sailship. when i tried to start my diving comressor the onan didnt work .... on the output there are just 177 volt instead of 220.
do you have an idea what happened to my generator?
I am sorry for writing like that but I didn't find anything in the forum for an onan 6,5 mdkd. best regards, roman...(rae1968@gmx.at .... +436643431551)
This is the Onan forum: https://www.smokstak.com/forum/forumdisplay.php?f=1
I'll post this up there so that maybe someone will recognize your unit and its ailment.
skip to joy profile: https://www.smokstak.com/forum/member.php?u=105778
The Following User Says Thank You to Harry For This Post:
Old 03-18-2017, 08:41:29 PM
Default Re: Onan 6.5 MDKDP26501C output 177 Volts instead of 220
What is the rated voltage and frequency of the unit? I'm guessing maybe 220V, 50Hz.
My first move would be to check the engine speed or output frequency, if you have the means to do so.
Old 03-18-2017, 08:47:07 PM
len k len k is offline
Looks like manual number maybe 981 -0502
http://www.twinslan.net/~n0nas/manuals/onan/
Looks like YD genhead, Section 5 onward of that manual.
Interestingly they came with either electronic voltage reg or current transformer "reg". Which one do you have?
Old 03-19-2017, 04:10:47 AM
skip to joy skip to joy is offline
Hello len k, thank you for answering, .... yes, it's a 220v 50hz
The engine speed is like always before, .... the motor had a refit 2 years before, he runs perfect.
After switching a big load (starting a diving compressor) there was no full output anymore. Maybe you have any idea which parts I may have damaged. Thank you.
Sorry, I ment Wayne 440
Hello len k, ..... my wiring diagram numbers are
612-6184-04
And
612-6187-02
Maybe this is important for you to help me.
Thanks a lot for helping me
Best regards
Roman
(From austria)
Old 03-19-2017, 08:12:41 AM
Gunny Gunny is offline
Check the voltage regulator output. The wires should be labeled X1 and X2 or possibly F1 and F2. With the generator running t the usual speed and no load, should be around 12 to 14 volts DC (not AC).
If OK, apply some load and check again, should go up with the load.
If voltage regulator output is low, I'd suspect the voltage regulator. If high, probably a failed rotating diode.
The regulator can be rebuilt or repaired. Diodes can be purchased from an Onan parts source.
The Following User Says Thank You to Gunny For This Post:
Old 03-19-2017, 12:52:17 PM
BigBlockChev's Avatar
The MDKD gen end is very similar to a YD gen end physically but mostly they use transformer regulation , some have an electronic voltage regulator . The most common failure that I have seen is the bridge rectifier in the control box or especially on marine generators the exciter coil corrodes through. I would check those two things first. Cheers Dan
It's always something simple.
The Feynman method , teach it to a kid , then you understand it.
The Following 2 Users Say Thank You to BigBlockChev For This Post:
Old 11-09-2017, 10:27:30 AM
theancientmariner theancientmariner is offline
Location: Charleston, South Carolina / Saint Vincent And The Grenadines
Have you solved your problem?
Old 11-09-2017, 02:07:12 PM
grif grif is offline
Wish I could remember where 177 came from. Wasn't that a weird lighting circuit voltage?
Old 11-09-2017, 02:39:50 PM
Probably thinking of 377 which is a lighting circuit voltage off one leg of 600V 3ph , used here in Canada. Cheers Dan
Old 11-09-2017, 06:52:21 PM
Vanman Vanman is offline
Or could be thinking of the 277 of 277/480, a standard commercial voltage.
Onan 6.0 DJB 37 volts for $400 sharpnose Onan Generators 55 10-05-2016 05:58:57 PM
Onan 6kw only putting out 40 volts rossmigues Onan Generators 105 08-22-2016 08:44:08 PM
high volts onan gen swtour Onan Generators 2 08-22-2012 12:42:55 AM
Buzz coil 6 volts or 12 volts? krazzyp Magnetos, Ignition Coils and Spark Plugs 2 06-26-2012 07:43:38 PM
Onan DKD with low AC volts used2b Onan Generators 6 06-07-2011 01:13:11 PM
