Onan MDL4 Fuel Issue
this thread has 10 replies and has been viewed 600 times
Old 09-04-2017, 09:54:48 AM
ageless1 ageless1 is offline
Default Onan MDL4 Fuel Issue
I have a 20kw marine generator that is spilling fuel into the exhaust. When I shut the fuel valve off the sheen out the exhaust stops. I don't have access to my manual until I get back to the boat and twinscan is down so I though I'd pick the experts brains
Old 09-04-2017, 10:27:00 AM
Billy J Shafer's Avatar
Default Re: Onan MDL4 fuel issue
If the oil level is normal. The only other way is a bad injector leaking fuel into the cylinder.
Old 09-04-2017, 10:32:59 AM
Email NOT Working
What do you mean when you shut the fuel valve off the sheen stops? Doesn't the engine stop running when you do this?
Old 09-04-2017, 10:47:55 AM
Not loading it down enough and wet stacking? Thermostat stuck open and not running warm enough?
As mentioned above, without a little more detail of what is going on it's hard to say what is being asked.
Old 09-04-2017, 10:48:25 AM
AngrySailor AngrySailor is offline
Does it have a fuel cooler? If the cooler sea water is piped to a wet exhaust could explain your issue
Old 02-12-2018, 01:28:32 PM
Sorry I haven't followed up on this, discovered the sheen issue was not from the generator, but I do have a new issue.
Model number: 20MDL4-3CR/25804B
Serial number is D870891256
I noticed my fuel filter was leaking (while running)when in the process of changing. Once I installed the new filter I continued to get a leak from the back side of the filter. I removed the two nipples that the filter slides on to ensure they weren't damaged, and I see nothing abnormal. I installed them back, checked the filter inserts to ensure no damage and placed the filter back on---still leaks.
My manual doesn't reflect the removable nipples so I am not sure of the answer to this but are those nipples supposed to have o-rings on the end that pushes into the mounting plate?
Old 02-12-2018, 01:33:21 PM
here is the filter
Old 02-12-2018, 01:33:49 PM
BigBlockChev's Avatar
A few pics would be good , your model is not common enough that many guys would have direct experience with it but a number of the Stakkers have many years of general experience. Cheers Dan
It's always something simple.
The Feynman method , teach it to a kid , then you understand it.
Old 02-12-2018, 01:37:33 PM
here is one of the nipples
Old 02-12-2018, 01:56:34 PM
There should be two o-rings on the filter. That seal off the system. I have never seen the nipple come off. Clean it off well and see where the fuel is coming from.
Onan 30.0DL6 starting issue because of lack of fuel sportmodel Onan Generators 2 05-26-2015 02:23:47 PM
Onan 2.5 KVD GenSet regulator/fuel issue fjrjohnny Onan Generators 7 09-17-2014 09:00:04 AM
Onan BFA fuel pump issue fenders Onan Generators 5 04-17-2012 07:23:31 AM
Onan MDL4 smoke issue after fuel pump rebuild arielmiller Onan Generators 9 01-06-2011 03:42:29 AM
Onan MDL4 fuel injector pump arielmiller Onan Generators 2 11-28-2010 03:48:29 AM
