Onan 12MDJC-3R/2268D Serial #16c859299 White Smoke
this thread has 93 replies and has been viewed 3738 times
Old 01-04-2018, 05:48:58 PM
BigBlockChev's Avatar
Default Re: Onan 12MDJC-3R/2268D Serial #16c859299 White Smoke
Lines look right to me. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
Old 01-04-2018, 06:22:52 PM
sscummins sscummins is offline
Hey Guys, this is my plan to check after thevalve clearance and spray pattern, attached is the page I have for inj pump timing, I will have to use method 2, I dont have a depth microp
ID:	299751   Click image for larger version
ID:	299752   Click image for larger version
ID:	299753   Click image for larger version
The Following User Says Thank You to sscummins For This Post:
  #23
Old 01-04-2018, 08:03:11 PM
Motorhead's Avatar
Measuring each injector volume PER SPRAY EVENT would be a good idea. That's essentially what a diesel injection shop does other than they measure it through the throttle ranges.
Correct me if I am wrong, does the injection pump START at full stroke (Full throttle) or does the governor limit for starting?
BBC in Canada seems to have a lot of acquired knowledge about these machines.
This will be interesting to find out what the problem is. Keep us posted.
The Control panel
and gauges of my
7.5JB
The Following 3 Users Say Thank You to Motorhead For This Post:
  #24
Old 01-05-2018, 07:21:00 AM
lokay5's Avatar
lokay5 lokay5 is offline
From what I remember, white smoke means a new Pope has been elected...
1973 CK5 Blazer
The Following 3 Users Say Thank You to lokay5 For This Post:
  #25
Old 01-05-2018, 09:57:28 AM
Motorhead, I dont know what you mean exactly about starting at full throttle or not? if youre asking if it starts at 1800 rpm and remains there the whole time load or no load from the head then the answer is yes, it does. I will look into contacting BBC, anything special this stands for BBC, I will try to google and see what comes up..
Last night I had the itch and I was looking verry closely at the marks, and this is what I found, might be something or not, so the inj pump has a hole on the side, like a pin hole to match up the pump (zero mark I will call it) that is supposed to match up exactly with the PC mark on flywheel. correct? well I used an allen wrench to slip in and there is 3 flywheel teeth (NOT PLAY) but solid turn FW (flywheel) and pump moves with it, no play at all. BUT here is the findings,I can turn the FW till it stops from allen stopping it and go the other way till it stops and 1st it stops 1 tooth before PC and turn FW other way like its running clockwise and allen stops it at 2 teeth past PC see pics. you can see the PC marking before PC and second pic is 2 teeth after PC where you cant see ther marking PC. so am I off 1 tooth?
Name:	1 tooth before PC.jpg
ID:	299788   Click image for larger version
Name:	2 teeth past PC.jpg
Old 01-05-2018, 10:00:02 AM
So in a short sentence I am not literally in the center of the 3 teeth movement around the PC mark. I dont know if I pull IP and move it 1 tooth will it correct it or still be off just on the other side of the PC mark.??? any thoughts???
Thanks Motorhead
Steve
Old 01-05-2018, 11:01:31 AM
Billy J Shafer's Avatar
Get manual 974-0750 go to the section on timing the JC. Looks like you are getting the two confused.
Old 01-05-2018, 12:40:51 PM
zuhnc zuhnc is offline
Any generator set with a mechanical governor, gasoline, gaseous or diesel, will start at full fuel/wide open throttle. As the engine comes up to rated/set speed (3600, 1800, whatever), the governor will close the throttle/fuel rack to supply just enough fuel for rated speed and load. Most electronic governors will exhibit this same behaviour. Others will have to chime in on the electronic governor operation. I do know that my (sorry, guys) Generac electronic governor retrofit on my 4.0cck starts at wide open throttle and then closes to rated speed/load. zuhnc
The Following 4 Users Say Thank You to zuhnc For This Post:
  #29
Old 01-05-2018, 01:14:28 PM
Billy J Shafer,
Thanks, I am looking at it on my breaks here at work, which 2 am I confused on, should I check it with the depth micrometer? checking on the shims being correct or not? or what else is there to check?
By the way, I was reading this manual and it shows in diagram 63 page 54 that there is supposed to be a Gasket?????? OOPS there wasnt one there when I took the pump off to be rebuild, just the shims were there? could this be or at least add to the problem??? ANYONE/EVERYONE? Please advise.
Steve
Old 01-05-2018, 02:33:46 PM
Dan, would not having a gasket on the ip make this type of a difference in running or at least add to it or not?
12mdjc-3r/2268d s/n 16c859299 sscummins Onan Generators 0 08-02-2017 02:47:17 PM
Allis Chalmers/ Onan 685T engine white smoke gen51 Multi-Cylinder Stationary Engines and Power Units 4 02-27-2013 11:10:10 PM
Onan 12MDJC-3r/2268d 120 output only? Tburk49760 Onan Generators 5 12-07-2011 10:36:21 AM
Onan 12.DJC-18R Lots of white smoke? checkpoint Onan Generators 13 02-07-2010 05:49:00 PM
I have white smoke baroling out of my Onan Emerald 1 genset philboy83 Onan Generators 7 01-11-2010 01:34:13 PM
