Onan Marine Generator
this thread has 53 replies and has been viewed 2379 times
Old 01-23-2018, 06:06:37 PM
Topman Topman is offline
Default Onan Marine Generator
I am new to this forum and I hope that someone can help me identify this genset.
Model: 3A1 . 7 _ G (M)
Serial: 53138238
Thanks, Iver
Name:	Onan genset serial.jpg
Old 01-23-2018, 06:34:07 PM
Billy J Shafer's Avatar
Default Re: Onan Marine Generator.
Need more pictures than that. That tag looks like several that I know of. Be glad to help.
Old 01-23-2018, 10:40:00 PM
Thanks for that. I will take more pictures next time I see it.
I am looking to buy the unit. It is an Onan 12.5kw.
Just thought that the Model # and Serial # might be of help to identify.
Thanks, Iver.
Old 01-24-2018, 12:00:38 AM
I looked up the 3A1 number. It shows to be a 15KW unit. But it doesn't tell me the Onan/Cummins code. I will see what I can find.
Old 01-24-2018, 05:04:54 AM
Thank you....
I was told the genset is a marine model.
It was removed because the heat exchanger failed so they replaced the complete generator with a new unit. My plan would be to convert it to land-based and install a radiator.
Thanks, Iver.
Old 01-25-2018, 12:15:35 AM
Going to check out this compressor tomorrow.
What should I look out for or what should I be aware of when looking at the unit?
Thanks, Iver.
Old 01-25-2018, 01:02:13 AM
Make sure it turns over. Should be a little hard from the compression.
Look it over for damage has it been hit or dropped.
Check the oil for water.
How rusty is it. Will have some but not to the point. Where parts are falling off.
Check the controls for burns or damage. If the wiring is burned you will smell it.
Check for damage from mice or bugs.
Is it what you want.
Old 01-25-2018, 01:05:37 AM
BigBlockChev's Avatar
Does it start easy , does it make power, does it smoke. A corroded heat exchanger is not a very good reason to replace a working generator . If it is the same one that has been for sale for a couple of months . If the hours are high it may need some engine work.Cheers Dan
It's always something simple.
The Feynman method , teach it to a kid , then you understand it.
The Following 2 Users Say Thank You to BigBlockChev For This Post:
Old 01-25-2018, 01:09:34 AM
I was thinking that also. Why change the whole unit over one part. I would look it over very well.
Old 01-25-2018, 01:37:55 AM
AngrySailor AngrySailor is offline
Salt or fresh water? Check for corrosion!
The Following User Says Thank You to AngrySailor For This Post:
onan majb 3k marine generator bay2550 Magnetos, Ignition Coils and Spark Plugs 1 03-11-2015 03:22:33 PM
onan diesel marine generator help lednum44 Onan Generators 2 10-18-2013 09:31:20 AM
Onan Marine Generator pholt Onan Generators 1 09-07-2013 01:34:36 PM
Onan Marine Generator J.B. Castagnos Onan Generators 7 11-10-2007 10:34:02 PM
Onan Generator- Marine Kim Pursell Onan Generators 1 12-17-2006 02:54:37 PM
