Onan Marine Generator
this thread has 53 replies and has been viewed 2117 times
Old 02-13-2018, 12:59:29 AM
Topman Topman is offline
Default Re: Onan Marine Generator
Originally Posted by Wayne 440 View Post
That one looks like it has a reasonable install of an air cleaner to me.
If yours is like it, why not do the same?
All I can see is the name Donaldson in the picture. Not sure if it is an OEM filter or not. I will try to check Donaldson for pictures.
Thanks, Iver.
Originally Posted by AngrySailor View Post
What material is it? I have a marine twin turbo setup for a BBC that uses water jacketed aluminum manifolds... they will melt in a heartbeat if run dry I can't imagine cast iron would fare much better with the outer jacket insulating the inner thus retaining extra heat... they were designed to be water cooled
The manifold and heat exchanger are cast iron.
Now that I found out the direction of coolant flow, I have decided to keep the marine manifold and run coolant through it and then through the radiator and back to the engine.
I got a small rad with a fan to try so I guess it will be trial and error for now.
Thanks, Iver.
Old 02-13-2018, 01:13:36 AM
AngrySailor AngrySailor is offline
It's a diesel so EGT will be lower, the manifold will only get as hot as the EGT, but could possibly set up stresses between the hotter inner portion and cooler outer portion... I think if you're going to retain the wet manifold it should be water cooled! This will also add to the heat required to be dissipated by your radiator/fan set up. I'm sure you'll get it working though
The Following User Says Thank You to AngrySailor For This Post:
  #53
Old 02-13-2018, 05:06:47 AM
Thanks AngrySailor,
I appreciate your optimism.
Yes, the manifold will now be water cooled. Just hoping the radiator can reduce water temperature enough.
I now have the generator mounted on a dolly and am putting together hoses for the radiator. I'll post pictures when I get ready to test.
Thanks, Iver.
The Following User Says Thank You to Topman For This Post:
  #54
Old 02-17-2018, 05:28:59 AM
Okay, the radiator and hoses are all hooked up. Installed a small fuel tank and a Donaldson air filter. The coolant now circulates completely through the water cooled exhaust, heat exchanger and radiator.
I started and ran the generator for awhile until I saw the temperature rise on the gauge. I let it continue to rise to 180* or so and then turned the fan on the radiator manually and the temperature dropped and continued to drop until I shut off the fan.
I now need to install a thermal switch to control the radiator fan.
Everything, so far so good.......
ID:	303352   Click image for larger version
The Following 4 Users Say Thank You to Topman For This Post:
onan majb 3k marine generator bay2550 Magnetos, Ignition Coils and Spark Plugs 1 03-11-2015 03:22:33 PM
onan diesel marine generator help lednum44 Onan Generators 2 10-18-2013 09:31:20 AM
Onan Marine Generator pholt Onan Generators 1 09-07-2013 01:34:36 PM
Onan Marine Generator J.B. Castagnos Onan Generators 7 11-10-2007 10:34:02 PM
Onan Generator- Marine Kim Pursell Onan Generators 1 12-17-2006 02:54:37 PM
