"New to me" Onan 30EK
this thread has 23 replies and has been viewed 1065 times
Old 02-03-2018, 09:06:17 PM
Default "New to me" Onan 30EK
30EK -4R871675A serial number 0969131584
I have lost my CD of documentation - so could one of you guys take pity on me and furnish the build sheet? This one is a bit different- gasoline fueled only.
Old 02-03-2018, 09:16:23 PM
Default Re: "New to me" Onan 30EK
I did not find it, got close but lacking the last 2 numbers.
Maybe one of the "pros" can have better luck.
The Following User Says Thank You to Max Thompson For This Post:
Old 02-03-2018, 10:26:59 PM
MBB MBB is offline
I looked also no luck. I posted it in the other thread but its gone unless i posted it in the wrong post. It wasn't correct though.
---------- Post added at 08:26:59 PM ---------- Previous post was at 08:11:56 PM ----------
I had an idea something wasn't right Wayne I believe your model is
30EK-4R8/1675A The 7 you were adding is really / . So here you go.
The Following 4 Users Say Thank You to MBB For This Post:
Old 02-03-2018, 11:09:32 PM
Thanks. That is probably correct. I have not even looked at the tag for myself yet. Got home, parked the truck, put the set's battery on a charger and called it a day.
Old 02-04-2018, 12:49:04 AM
Jim McIntyre's Avatar
120/208, eh? Is it really a 12-wire set though?
Old 02-04-2018, 02:23:13 AM
The posted build sheet says 4 wire. 4R voltage code.
Old 02-04-2018, 04:46:27 AM
I'm thinking that it is probably going to have only 4 wires that are readily accessible, but have not looked into it yet.
Old 02-04-2018, 09:11:15 AM
MBB MBB is offline
Come on Wayne get up and get us some pictures.
Old 02-04-2018, 10:32:27 AM
Dropped my phone a while back and took out the camera lens, pics look like viewing thru a heavy fog. Appreciate the quick response from you guys, this is the first gasoline EK I have seen.
The battery appears to be bad, but it didn't hurt to try. 30EK-4R8/1675A is the correct number.
Old 02-05-2018, 08:15:38 PM
Planning to try cranking it up tomorrow. Have a couple of oil filters on hand, oil and coolant. Since I don't have anything else to go on, I'll guess that it last ran in 2014, since the battery is dated with same.
Need Cont'l Engine Book Help Re' "N", "NA", "N-NA" Engine Confusion 1915-25 Bud Tierney Antique Autos and Trucks 0 11-06-2015 04:04:38 PM
"Shoot-a-lite" safety gas "Liter", Turner and Seymour Mfg. Co. Dwayne Oxford Welding Shop 5 03-19-2015 11:45:56 AM
Fairbanks-Morse "Z" style "C" 3 HP Dishpan Multi-Fuel David M. Lyon YouTube Old Iron Videos 0 11-09-2010 09:23:11 PM
I got my Onan 5.0 CCK "Project" -needs "some" coil(s) macinco Onan Generators 4 05-22-2009 09:19:37 AM
