Onan 6.5NH Exhaust Leak Question
this thread has 12 replies and has been viewed 625 times
Old 02-05-2018, 01:40:28 AM
mvimpvm mvimpvm is offline
Default Onan 6.5NH Exhaust Leak Question
Hey all, got a quick question. I have an exhaust leak that is messing up my paint job. Has a new metal OEM gasket on there but still a leak. Anybody got any suggestions? I attached a picture. It is the joint about 4 inches above the flex pipe. That is not a shadow but carbon from exhaust on my paint.
Old 02-05-2018, 02:27:23 AM
Default Re: Onan 6.5NH Exhaust leak question
Try to file both flanges flatter than high temp. silicone on both sides upon assemble, let dry and go.
The Following 2 Users Say Thank You to nothingbutdarts For This Post:
Old 02-05-2018, 02:29:06 AM
geezer88 geezer88 is offline
My NH6.5 leaked in the same place. The flanges were badly warped, so no gasket would hold. I use a grinder to flatten the flanges and all is well.
tom
The Following 3 Users Say Thank You to geezer88 For This Post:
Old 02-05-2018, 08:05:36 AM
I agree with both above posts. Flanges must be "flat" in order to seal.
It looks like you are also leaking at the flex connection. Looks like some black showing around the clamp. That is a tough joint to make air tight. You may have to weld the flex to the tail pipe.
The Following 2 Users Say Thank You to Max Thompson For This Post:
Old 02-05-2018, 09:08:53 AM
Billy J Shafer's Avatar
That was a common problem with RV units. Take and grind the flange down flat. That was what we always did. On the pipe we split it or had it welded. That was a hard place to seal off. Some times two clamps around the section worked.
The Following 2 Users Say Thank You to Billy J Shafer For This Post:
Old 02-05-2018, 09:53:42 AM
KPack KPack is offline
Did you have to split the flex to make it go over the pipe ?
The Following User Says Thank You to KPack For This Post:
Old 02-05-2018, 10:13:40 AM
consolenut consolenut is offline
I doubled the metal gasket. Then used the orange high temp RTV on it. No issues so far.
The Following User Says Thank You to consolenut For This Post:
Old 02-05-2018, 09:12:55 PM
Did you all just use something like a 7" angle grinder with a flat wheel to do the grinding or just a flat file?
Old 02-05-2018, 09:25:13 PM
Default Re: Onan 6.5NH Exhaust Leak Question
A grinder or a file. Will work just depends on how much room you have.
Old 02-05-2018, 11:19:49 PM
Vanman Vanman is offline
It seems to me that these flanges are getting bent by over tightening in the past. I'd think it would be best to first try to bend them back as much as possible, then finish by grinding, thereby leaving as much material intact as possible. Maybe even provide relief around the bolt holes, so that the sealing surfaces contact first. Then just snug up the bolts enough to clamp the gasket, but not so much as to bend the flanges again. Those should have been made with thicker flanges and / or more bolts.
The Following 5 Users Say Thank You to Vanman For This Post:
Onan 6.5 RV Spec K Exhaust Leak? turbojimmy Onan Generators 4 01-18-2015 11:56:20 AM
onan 5.0 cck wiring question and oil leak Jmader Onan Generators 12 02-23-2014 01:16:34 AM
Onan JC 12.5 exhaust question? flagmaster Onan Generators 18 10-26-2013 12:41:59 PM
Onan 12.5JC a different exhaust question curtis.stanley Onan Generators 3 10-21-2013 11:28:34 PM
Onan DJE exhaust/manifold question ichudov Onan Generators 3 04-16-2005 10:21:09 AM
