Onan 6.5NH Exhaust Leak Question
this thread has 12 replies and has been viewed 746 times
Old 02-06-2018, 07:58:12 PM
Jim Marcozzi Jim Marcozzi is offline
Default Re: Onan 6.5NH Exhaust Leak Question
Flatten the flanges with a belt sander.
Install new gasket. DO NOT over tighten a soft gasket- the flange will warp.
For the flex, use a walker or nelson band clamp such as:
http://www.walkerheavyduty.com/en-US...mp-band-clamps
These clamps tighten evenly 360 degrees and seal better than any saddle clamp.
The Following 3 Users Say Thank You to Jim Marcozzi For This Post:
Old 02-07-2018, 10:32:55 AM
armandh armandh is offline
my 6.5 NH used exhaust tubing in both OD and ID sizes for slip on fit-up
in the end my exhaust relied on 3 to 4 inch overlap to the flex, and no clamps
[I welded a piece of OD measured tubing inside the ID measured flange stump]
https://www.smokstak.com/forum/attac...7&d=1476101570
[used outside]
by using this free advise, you, your heirs, etc
absolve, save, and hold harmless the advisor.
CAVEAT EMPTOR
YMMV
Old 02-09-2018, 01:27:24 AM
mvimpvm mvimpvm is offline
Nice! I think mine is a bit too tight to slide it up that far. Had to split it to get it in as far as I did.
Thanks Jim for that Walker clamp idea. I am ordering a couple of those!
Onan 6.5 RV Spec K Exhaust Leak? turbojimmy Onan Generators 4 01-18-2015 11:56:20 AM
onan 5.0 cck wiring question and oil leak Jmader Onan Generators 12 02-23-2014 01:16:34 AM
Onan JC 12.5 exhaust question? flagmaster Onan Generators 18 10-26-2013 12:41:59 PM
Onan 12.5JC a different exhaust question curtis.stanley Onan Generators 3 10-21-2013 11:28:34 PM
Onan DJE exhaust/manifold question ichudov Onan Generators 3 04-16-2005 10:21:09 AM
