Kubota Z482 - Question Regarding Alternator
this thread has 20 replies and has been viewed 1032 times
Old 02-06-2018, 08:03:41 PM
Nasr Nasr is offline
Default Kubota Z482 - Question Regarding Alternator
First let my apologize. I could not find a section dedicated to kubota engines.
If this fits in a different section please feel free to move it
I am building a generator. I have a question
Will i be able to use a 1800 rpm alternator with a 3600 rpm engine?
This engine has a sae 5/6.5 flywheel so it will be direct drive.
Old 02-06-2018, 08:22:15 PM
OEM Volunteer OEM Volunteer is offline
Default Re: Kubota z482 - question regarding alternator
Others here have talked about marrying 1800 rpm and 3600 rpm components but, have always used pulley set ups.
https://www.smokstak.com/forum/showthread.php?t=121845
I'm not sure 1800/3600 direct drive you're proposing is possible but, the resident smart guys would know best. Maybe they'll chime in.
Old 02-06-2018, 08:23:05 PM
Jim McIntyre's Avatar
Jim McIntyre Jim McIntyre is online now
As a practical matter, no.
If you turn 1800 rpm 60 Hz alternator at 3600 rpm, you'll get 120 Hz power instead of 60 Hz. There is no way around this.
And if you run your 3600 rpm engine at 1800 rpm, you'll get about half its rated horsepower.
Old 02-06-2018, 09:34:56 PM
JohnnyC JohnnyC is online now
I got a stupid question so forgive me if I'm missing something here, but can you govern down the motor from what I assume is a constant 3600 rpm to 1800 rpm? Ok, I'll be quiet now
JohnnyC
New Jersey
Old 02-06-2018, 10:02:32 PM
Why would you run a diesel at 3600 RPM? Many modern diesels can do it, but it's going to be loud and that speed is really not good for them
Find a power chart for your engine, and see how many horsepower it can make at 1800 RPM, and you can roughly assume you can get 1 kw per 2 hp.
Diesels have rarely been worth a gearbox and I can't think of any that use one. Generac uses them on spark ignited engines but that's because spark engines aren't happy at 1800 RPM
The Following User Says Thank You to pegasuspinto For This Post:
Old 02-06-2018, 10:55:10 PM
Originally Posted by JohnnyC View Post
...but can you govern down the motor from what I assume is a constant 3600 rpm to 1800 rpm? ...
Sure - the Z482 engine's good for a tad over 5 kW at 1800 rpm. Factor in the efficiency of the alternator itself, and you'd be at around 4 kW.
Old 02-06-2018, 11:26:16 PM
That chart makes it appear you can get to 3600, but that is red line. Don't expect the engine to last long there.
Old 02-06-2018, 11:27:39 PM
BigBlockChev's Avatar
You should be able to get a 2 pole 3600 RPM alternator with the correct SAE coupling disc to bolt up. Or use some sort of cogbelt 2-1 drive setup . Seems easier to change the engine or alternator to something that just fits though. Cheers Dan
It's always something simple.
The Feynman method , teach it to a kid , then you understand it.
Old 02-06-2018, 11:32:58 PM
Email NOT Working
I have a customer with a factory MQ generator running at 3600 RPM. I'll let you know in a year or two how it does. I have been told over and over that these smaller diesels are fine at 3600 but I will not sell one to anybody.
Edit: to be clear the MQ is also a Z482 so we shall see.
Old 02-07-2018, 12:09:53 AM
Default Re: Kubota z482 - Question Regarding Alternator
Maybe a small set in 'light duty' standby would be OK. I want to see a 16v71 scream up to 3600! I am pretty sure the sound waves would open up microfissures in the fabric of space.
The Following 2 Users Say Thank You to pegasuspinto For This Post:
Kubota injector question I like oldstuff Carburetors, Mixers, Fuel Pumps and fuel delivery 5 09-01-2017 12:28:08 AM
Kubota general question, help with what causes overspeed to trip rian.dale73 Generators & Electric Motors General Discussion 4 05-17-2016 03:32:41 PM
Kubota Z482 Diesel powered generator DZelmer Generators & Electric Motors General Discussion 16 07-29-2015 01:48:39 AM
Kubota Z482 Dieselfan Vintage Diesel and Oil Engines 27 11-10-2012 06:10:35 PM
Alternator Question Ron Beddome Generators & Electric Motors General Discussion 6 03-18-2007 06:07:15 PM
