Kubota Z482 - Question Regarding Alternator
this thread has 20 replies and has been viewed 1037 times
Old 02-07-2018, 12:19:50 AM
AngrySailor AngrySailor is offline
Default Re: Kubota z482 - Question Regarding Alternator
Pegasuspinto, see the pics in runaway 12v149 thread for an explanation of our shift to a parallel dimension... it wasn't CERN that caused that
By the power curve posted, that engine makes 5hp at 1800rpm or about 6.7kw. Usually the engine is rated double the generator capacity so it's not going to work well at 1:1... maybe steady 4kw lugging like crazy. There are ways around this, or marry parts that work together may be easier/better solution. Just my $0.02
Edit, I didn't notice the BSFC was posted i that chart... if you had a 2 pole generator or reduction gearing/belting, you would get almost double the power for minimal extra fuel, less friction losses. That engine needs a 2 pole 3600 rpm direct drive generator for maximum efficiency!
The Following User Says Thank You to AngrySailor For This Post:
Old 02-07-2018, 12:42:56 AM
Vanman Vanman is offline
I would be highly doubtful that the engine would be more efficient screaming away. Speaking of that, is the timing adjustable on these? Optimizing the timing for the sane rpm of 1800 would make it even more efficient at the slower speed.
But here's another question- how many kw is the existing 4 pole generator?
As an aside, there is absolutely no way I would ever deliberately set up an engine to run at 3600 rpm. You've got already got a 4 pole generator, it'll bolt up to the nice engine you already have. If the generator is 4 or 5 kw, bolt 'em together, adjust the governor to 1800, and enjoy a sweet generator set!
Old 02-07-2018, 12:55:17 AM
Jim McIntyre's Avatar
Look again. It's 5 kW at 1800 rpm.
No. The BSFC is actually better at 1800 rpm than at 3600 rpm.
Old 02-07-2018, 01:15:45 AM
It DOES say "engine horsepower (kw)" Kinda goofy
container gallons in liters?
rope feet in meters?
I could go on but it hurts the brain!
Old 02-07-2018, 01:22:06 AM
Does it use DOUBLE at 3600? For TWICE THE POWER?
And your right it IS Kw, damn phone posters... that's even worse though! It's only a 2.5 kw generator now.
I may have jumped too soon
Wait... does it say g/kWh? If so you're right
We can't argue this without knowing actual load really.
Old 02-07-2018, 08:52:46 AM
Normally, I'm an advocate for "slow" running machines. But at some point the bore and stroke get low enough that 3600 is relatively slow - a Z482 is about half the displacement of a DJB. I would have no issue with that engine for standby use at 3600, the stroke is 2.68 inches, and bore 2.64 so the piston speed is not all that fast.
That said, there is little doubt that it would last longer at a lower speed.
The Following 2 Users Say Thank You to Wayne 440 For This Post:
Old 02-07-2018, 10:55:54 AM
That engine isn't very smooth at 1800. If I were designing from scratch, I would run it at +/-2600RPM, which is the peak in the torque curve, and belt it up or down.. The governor on your engine might be limited, and I wouldn't be afraid one bit to run it at 3600, if that's where the governor range is. Depends on the former application of the engine. There are models designed to scream. it's a sub-500cc z482... Don't try to compare it to other engines, except maybe a yanmar 2TN.
Old 02-07-2018, 12:55:15 PM
Default Re: Kubota Z482 - Question Regarding Alternator
To answer the OP's question - No, not direct drive. Has to be belted.. In theory you could bypass two poles and get some sort of 60Hz at 3600, but the rotor was not designed to spin that fast..
Old 02-07-2018, 12:58:00 PM
...Wait... does it say g/kWh?....
Yes. That's what the 'S' in BSFC means - the fuel consumption is based on a 'per kW' (or 'per HP') basis.
https://en.wikipedia.org/wiki/Brake_...el_consumption
Old 02-07-2018, 02:42:57 PM
Motorhead's Avatar
One KW is equal to 1.34102 horse power. So 5 KW is equal to 6.70 HP
The little Z482 is a hell of an engine. I had an early Kubota B5100D and it would pull its little heart out. Only drawback to mine was it was a thermo-siphon cooling system, No water pump. Later ones had a water pump.
My 1939 WILLYS Pickup.
Bought in 1971
Kubota injector question I like oldstuff Carburetors, Mixers, Fuel Pumps and fuel delivery 5 09-01-2017 12:28:08 AM
Kubota general question, help with what causes overspeed to trip rian.dale73 Generators & Electric Motors General Discussion 4 05-17-2016 03:32:41 PM
Kubota Z482 Diesel powered generator DZelmer Generators & Electric Motors General Discussion 16 07-29-2015 01:48:39 AM
Kubota Z482 Dieselfan Vintage Diesel and Oil Engines 27 11-10-2012 06:10:35 PM
Alternator Question Ron Beddome Generators & Electric Motors General Discussion 6 03-18-2007 06:07:15 PM
