Onan 12.5JC Sorting it Out
this thread has 77 replies and has been viewed 2800 times
Old 02-08-2018, 11:58:22 PM
consolenut consolenut is offline
Default Re: Onan 12.5JC Sorting it Out
Carb picture
Old 02-09-2018, 12:00:48 AM
Yeah i was planning an electric fuel pump.. If i can find a gas carb on ebay ill go that route. The oil was squeaky clean in it. And ill get the tune parts in the mean time. Aa i know using that big hose thats nornally for a propane line. Is not wise to draw gasolibe through.
Old 02-09-2018, 12:03:43 AM
JohnnyC JohnnyC is offline
Does your carburetor have the two small needle valves as seen in the picture below? I'm not sure if a gas only carburetor only has one and the other plugged???? I'd have to dig up some pictures from my 15.0JC refurb which had a gaseous carb.
JohnnyC
New Jersey
Old 02-09-2018, 12:08:45 AM
Yeah i was planning an electric fuel pump.. If i can find a gas carb on ebay ill go that route. The oil was squeaky clean in it. And ill get the tune parts in the mean time. As i know using that big hose thats nornally for a propane line. Is not wise to draw gasoline through.
---------- Post added at 12:08:45 AM ---------- Previous post was at 12:07:10 AM ----------
Yea it has the two needle valves on top and the larger one in the middle. Same as yours
Old 02-09-2018, 12:10:55 AM
As I thought.... Look at the picture below of a gaseous carb from my 15.0JC and notice that one of the smaller needle valves is missing. Check and see if yours is plugged and if it is, I wonder if the bore is threaded or not..
Old 02-09-2018, 12:13:16 AM
OK, I think we both posted at roughly the same time.... As you can see, my gaseous 15.0JC is missing one of the smaller needle valves and yours is not.. That's good. Are you sure yours does not have a float?
JohnnyC
New Jersey
Old 02-09-2018, 12:13:49 AM
There are the needle and seat you ask about. And the pickup tube where the needle and seat id assume threaded into in the bottom the carb isbthere as well. As inseen it when i took the bowl off.
The Following User Says Thank You to consolenut For This Post:
Old 02-09-2018, 12:17:59 AM
.... just to confirm that my gaseous carb from my 15.0JC does NOT have the third needle valve I attached several more pictures below from a different view. FWIW - not to confuse the idle stop as the needle valve in my pics below. Looks like my third is plugged.
JohnnyC
New Jersey
ID:	302700   Click image for larger version
Old 02-09-2018, 12:22:41 AM
Try to find a gasoline junk carb on FleaBay and transfer the missing parts for gasoline to your gaseous carb. Hopefully that is all you may need. Also make sure that the float needle seat in the body of your gaseous carb is threaded to accept a needle seat.
JohnnyC
New Jersey
Old 02-09-2018, 12:23:59 AM
As you can see in the bittommof the carb everythingnisbthere to hang the float etc.
