Onan 12.5JC Sorting it Out
this thread has 77 replies and has been viewed 2794 times
Old 02-09-2018, 09:10:30 PM
EnginePat EnginePat is online now
Default Re: Onan 12.5JC Sorting it Out
Video not working!
Pat
5GO 3/RA
7.5 jb's x4
6.0 DJE X 1
Old 02-09-2018, 09:18:10 PM
JohnnyC JohnnyC is offline
Originally Posted by EnginePat View Post
Video not working!
I wonder if the video upload to YouTube successfully.
JohnnyC
New Jersey
Old 02-09-2018, 09:31:40 PM
Look here for manuals:
http://onan.xmsi.net/
Old 02-09-2018, 09:52:01 PM
consolenut consolenut is offline
Try again i had the settings wrong
Old 02-09-2018, 09:55:02 PM
stretch67 stretch67 is offline
They did mention that and it smells like dirty socks.
The turbo guys like e85 as you can boost like crazy with it compared to pump gas.
Now in my truck which can do E85 the HP jumps from 355 to 380 but on pump gas i get about 650 kms per tank. With e85 you only get about 400. Less BTU in corn juice.
Old 02-09-2018, 10:11:58 PM
https://youtu.be/vDnRFuqg4KQ
The Following 2 Users Say Thank You to consolenut For This Post:
  #37
Old 02-10-2018, 07:40:12 AM
Viking66 Viking66 is offline
I didn't know it was going to become a Mobile type solution. Gasoline it is then
As Always....This Place is Awesome!!!!
Old 02-10-2018, 09:43:41 AM
Got a few questions! First i got it running and reconfigired for single phase. I have 230 volts across L1 and L2. That makes sense to me. However L0 is the confusing part. Initially i thought the leg that makes L0 got attached to stud in the bottom of the wiring box. Doing that i had 375 across L1 and L2. So i secured L0 and covered it so not touching anything. And the 230 was found across L1 and L2 as stated before. If i go from L1 or L2 each side to the lug i get 127 per side and that makes sense.
So when i connect the unit to my 70amp power panel. L1 and L2 i know where they go. But what to do with L0? Do i connect the neutral ground bar of the panel to the stud in the bottom.of the wiring box. That seems to be neutral? Then that being said is L0 connected anywhere?
My only other idea is L0 another 120 Volt leg?
Im.close i know im close just not sure where the finish line is?
Old 02-10-2018, 09:49:34 AM
I used this for assuring i connected the leads in correct manner
Old 02-10-2018, 10:10:46 AM
My suggestion is to take a close look at your connections again. "230" from L1-L2 and "127" to ground suggest that your wiring is wrong. Did you happen to check the voltage from L0 to L1, L2 while it was not grounded?
