Help, CCK Pumping Fuel From Carb
this thread has 8 replies and has been viewed 467 times
Old 02-09-2018, 09:07:53 AM
hertfordnc hertfordnc is offline
Default Help, CCK Pumping Fuel From Carb
I spent the previous few weeks getting this thing running and it was working perfectly 2 days ago
this morning it was cold here and hard to get started
Then it would run until fuel gushed out of the top of the carb.
I could keep it running indefinitely by disconnecting and reconnecting the fuel pump wire.
So does that mean stuck carb float?
Any old mechanic tricks I can try short of taking the carb off?
Old 02-09-2018, 09:19:43 AM
JohnnyC JohnnyC is offline
Default Re: Help, CCK PUMPING FUEL FROM CARB
Float in carb may be stuck keeping the needle valve open. Try rapping on the float bowl with a large screw driver handle. Or drop the bowl and work the float free as well as cleaning out any crap from the ethanol gas that may have evaporated over the last 2 years.
JohnnyC
New Jersey
The Following 3 Users Say Thank You to JohnnyC For This Post:
Old 02-09-2018, 10:14:51 AM
YellowLister YellowLister is online now
Default Re: Help, CCK Pumping Fuel From Carb
Like Johnny said it's the needle.. I would remove the line to the carb and blow it out, replace the rubber line if its old as the tend to deteriorate inside and pump little peices of rubber into the carb.. add a inline fuel filter, and clean out the fuel pump filter on the bottom of the pump if its the original onan fuel pump
Most have a metal line from the fuel pump to the carb if yours is rubber id replace it just to avoid it from happening again
Old 02-09-2018, 10:23:11 AM
Billy J Shafer's Avatar
There are many tricks that may work. For now. But the best way is to take it apart. Clean it out and if you have old rubber line. Replace it.
The Following 2 Users Say Thank You to Billy J Shafer For This Post:
Old 02-09-2018, 11:42:37 AM
it fixed itself (sort of)
I had a feeling it was caused by the cold, ice in the carb so i ran it for a while by cycling the fuel pump, got the exhaust hot and the closed it up and left it.
An hour later it's working.
I'm thinking a little dry-gas might help.
thanks
Old 02-09-2018, 12:29:27 PM
J.B. Castagnos J.B. Castagnos is online now
A quick fix for carb flooding is to stop fuel from entering and run the carb dry. If trash gets caught in the needle the float will hold it there, it will continue flooding. Shutting fuel allows the float to drop, incoming fuel washes the trash out, you may have accomplished this unknowingly.
Old 02-09-2018, 01:26:45 PM
Exclamation Re: Help, CCK Pumping Fuel From Carb
I would take the fuel bowl off and check for debris or water. Pull the float and needle and make sure there is no more debris in the inlet. If there is water, it will sit in the bowl and corrode it. if you use E-10, it certainly will mix with the alky in the gas and cause 'white rust'. If it was a piece of crud, it may float around for a while, and eventually end up in the main jet or worse, into the smaller idle circuits.
Old 02-09-2018, 02:05:10 PM
Fixed for now comes to mind.. but when you need it, it will magicly not start..
Spend the time to fix it right and keep it in good shape, it it will take care of you as you do it... all it Will cost you is a little time, and you will be more familiar with your onan and know it's ready to go
The Following 2 Users Say Thank You to YellowLister For This Post:
Old 02-10-2018, 10:45:30 AM
We all make choices. Right not the generator is in a non-running motorhome parked at a vacant house on which i am losing $850 a month until i get it renovated and rented.
I love the Onan and the motorhome and as soon as this project is wrapped the motorhome will be towed home where i have a garage and electricity.
Novo Fuel Pumping Station Larry K Antique Gas Engine Discussion 0 06-20-2016 10:03:06 PM
6hp fairbanks Z fuel not pumping? notsch92 Antique Gas Engine Discussion 7 08-27-2011 03:01:27 AM
IHC 1 1/2 hp M cast iron fuel pump (not pumping) Eric McKenna Antique Gas Engine Discussion 5 07-02-2009 09:01:09 AM
Not getting fuel into 6M carb Tim Claremont Antique Gas Engine Discussion 11 09-05-2006 08:50:33 AM
Florida Flywheeler Fall Fuel up? - Snow Pumping Engine TABest55 Antique Engine Archives 4 11-17-2004 12:11:22 PM
