Old Onan Electric Plant
this thread has 12 replies and has been viewed 736 times
Old 02-10-2018, 07:36:48 AM
Watts Watts is offline
Default Old Onan Electric Plant
I have an old Onan Electric Plant. I am trying to find out some information on the wiring that is coming out of the unit as well as age. I would also like to find an owners manual and parts and overhaul manual too. Model and Spec# 5CW 3R/768E. Ser# 107B3309. I have included some pics of the info tag and the unit itself. Thank you for any info you folks may have.
Old 02-10-2018, 07:49:13 AM
Default Re: Old Onan electric plant
Made oct 1957.. the 3r means it's 120 240v single phase
5 kw unit. The cw is a tank of a generator and way overbuilt
Twinslan.net is where you can find manuals via the model and spec, which is e
Welcome to the stak
The Following 2 Users Say Thank You to YellowLister For This Post:
Old 02-10-2018, 07:55:02 AM
Sorry. Pics didn't come thru. I'll try again.
ID:	302781   Click image for larger version
ID:	302782   Click image for larger version
ID:	302783   Click image for larger version
The Following User Says Thank You to Watts For This Post:
Old 02-10-2018, 07:59:07 AM
Smile Re: Old Onan electric plant
Any idea on how much this beast weighs? I have it sitti g on a good heavy 4 wheeled cart but I would like to know.
Old 02-10-2018, 08:18:41 AM
Looks very nice! And has the factory meter panel..
The 10 cw, 10 kw and 7.5 kw versions are about 800 pounds.. your is probably a little on the lighter side, but not by much.
If you don't already know.. you need a very hot high amp battery to fire one of these up..
Old 02-10-2018, 08:37:35 AM
I did not know that about the battery. I am using a good size marine battery now and seems to work OK. Maybe I should get something bigger? Thank you.
I purchased this old girl @ a fleamarket in Thompson Conneticut some 8 to 10 years ago for $400.00 dollars. We had quite a time loading it into my truck. Guess I know why now @ almost 800 lbs. WOW.
Old 02-10-2018, 09:04:02 AM
Pauls12 Pauls12 is offline
Welcome Watts, you can find your manuals here. http://onan.xmsi.net/
The Following 3 Users Say Thank You to Pauls12 For This Post:
Old 02-10-2018, 09:58:15 AM
EnginePat EnginePat is offline
Default Re: Old Onan Electric Plant
It must have a hefty winding ,44 amps for a 5k unit!
Pat
5GO 3/RA
7.5 jb's x4
6.0 DJE X 1
The Following User Says Thank You to EnginePat For This Post:
Old 02-10-2018, 11:24:11 AM
MBB MBB is offline
As Paul12 mentioned go to the link and on the keyboard press cntrl+f and search CW
The Following 2 Users Say Thank You to MBB For This Post:
Old 02-10-2018, 01:13:06 PM
HBSaunders HBSaunders is offline
Did a thread on a 10CW a while back myself without a data tag, read over that might be some info that may be of use. Yes it is way overbuilt, overweight but overall it's an ONAN. Royalty of American engineering that goes way back. As the song says treat her right and she'll give you a lot..... welcome to smokstak, Howard
The Following 2 Users Say Thank You to HBSaunders For This Post:
Onan electric plant skcurtis Onan Generators 6 07-07-2007 04:14:36 AM
Onan Electric Plant Paul H Onan Generators 4 02-27-2006 10:12:48 AM
Onan Electric Plant Brad Franken Onan Generators 6 04-08-2005 08:25:02 PM
ONAN Electric Plant C McKinlay Onan Generators 1 11-20-2004 11:04:18 AM
ONAN ELECTRIC PLANT mo Onan Generators 2 09-19-2003 05:56:12 PM
