Yet Another Onan CCK Question - Won't Run Compressor
this thread has 10 replies and has been viewed 755 times
Old 02-10-2018, 07:29:11 PM
Default Re: Yet another CCK question- won't run compressor
Originally Posted by hertfordnc View Post
...I'm not arguing or being defensive. Just trying to understand....which part of this creates a fire hazard?
Would it make a difference if i only used one leg?
Generally, I would not bother to follow up here since you are backfeeding, but you asked nicely, and passed the "attitude test".
When your panel is fed with the utility supplied 240V and neutral the two bus bars are out of phase with each other. The neutral carries only the difference in current between them.
As you have it now, the bus bars are in phase (fed from the same 120V source) and the neutral carries the entire load current, which may be more than it is sized for.
Powering only one bus bar in your panel should negate that possibility, IF all 240V loads were shut off.
Antique Compressor wiring question (Wagner) Wingaman Air Compressors 1 08-31-2017 10:54:01 AM
Compressor belted to engine question JKWidener Antique Gas Engine Discussion 4 10-17-2010 02:10:26 PM
Compressor question Joe Morris Antique Gas Engine Discussion 1 08-28-2008 12:07:23 PM
inverted air compressor question Greg Shipley Antique Gas Engine Discussion 6 02-17-2006 01:48:42 PM
air compressor/sand blaster question Chris Kirk Antique Engine Archives 4 03-19-2004 03:01:54 PM
