Onan 2.5LK-1R/12L
this thread has 105 replies and has been viewed 3859 times
Old 02-11-2018, 03:41:10 PM
JohnnyC JohnnyC is offline
Default Re: Onan 2.5LK-1R/12L
Okay, job done! I removed the fuel bowl filter assembly. It stunk like 30 year old gas and smelled up my garage worst than me after eating a bean burrito. I had to clean it since there would be no way to mail it to you and the glass bowl was stuck and had to be soaked in a solvent in order to separate the bowl from the filter housing. Since I went that far, I rebuilt it. It is like new now. PM me your mailing address. I will get a box at work tomorrow and send it off to you on Tuesday. If you can wait until after next weekend, I can paint it for you too.
Now I will be removing the parts I need for my LK. I feel like a desert buzzard picking away at road-kill.
JohnnyC
New Jersey
ID:	302925   Click image for larger version
ID:	302926   Click image for larger version
ID:	302927   Click image for larger version
Old 02-11-2018, 04:52:05 PM
I knew it! The Onan Gods are pissed at me for sacrificing the AK.... After I picked off the fuel filter assembly for Handyhiker1's LK, I went back to pick parts from the AK for the my LK. While removing the AK's power outlet box, the AK slipped off the furniture dolly it was resting on and onto two of my finger tips. One got cut and the other bruised under the base of the nail. Both fingers are stinging and not letting up after 30 minutes. The bleeding stopped, but without doubt I will loose 2 of my fingernails. The tips are not broken since I can bend them, but with lots of stinging pain. I would say the two finger tips got the full weight of the AK after it fell 5 or 6 inches off the dolly. It kind of felt like dropping an anvil 5 or 6 inches onto your finger tips. I am done for the day .
JohnnyC
New Jersey
Old 02-11-2018, 05:00:08 PM
Billy J Shafer's Avatar
Not nice to piss off the Onan GOD.
The Following 2 Users Say Thank You to Billy J Shafer For This Post:
  #24
Old 02-11-2018, 05:11:59 PM
Could have been worse.
The Following 7 Users Say Thank You to Wayne 440 For This Post:
  #25
Old 02-12-2018, 04:58:32 AM
Handyhiker1 Handyhiker1 is offline
Originally Posted by David C View Post
The tri-fuel LK I have has the gaseous fuel connection at that location. If it is drilled like the picture, you just need a valve and some hardware.
David C.
This may be a dumb question but I am not familiar with gaseous fuels. Never had a generator run on it. What type of control valve is needed since the carburetor does not have a flow adjustment needle valve? Also is there a small on demand regulator needed for this small of a generator?
Any info would be appreciated. I am really thinking that I would like to run this one on propane just not real sure on the set up.
Old 02-12-2018, 02:48:22 PM
I did a little research and have the entire set up on its way. Should have it in a couple of days. I will post a few pics when I get it all.
The Following User Says Thank You to Handyhiker1 For This Post:
  #27
Old 02-12-2018, 08:08:14 PM
Took a quick look at the carburetor today. I for sure am going to need a bowl gasket, needle valve and seat. It looks like the needle has been changed and now it doesn't shut off the fuel so the bowl overflows.
The good news, kind of, my other LK uses the same carburetor just not the tri fuel version. I am sure between the two of them I can restore the tri fuel then find parts or a carburator for the vacuflow unit.
Old 02-12-2018, 08:09:49 PM
David C David C is offline
Here is a couple of pictures of the gas adjustment valve and piping that came on my tri-fuel LK. Obviously the pictures were taken before any cleaning happened.
David C.
Name:	2.5LK Tri-Fuel (4).JPG
ID:	303044   Click image for larger version
Name:	2.5LK Tri-Fuel (5).JPG
The Following 2 Users Say Thank You to David C For This Post:
  #29
Old 02-12-2018, 08:14:50 PM
EICBob EICBob is offline
OUCH!!!!!
Been there, done that and NEVER got the “T” shirt!
Heal fast JohnnyC!
-Bob
Old 02-12-2018, 09:42:29 PM
It was a good night. Just ordered all the parts needed for the carburetor rebuild. I will rebuild the tri fuel carburetor and install the propane kit when it all showes up. Now just have to find an air cleaner.
