Does anyone have this Fuel Solenoid Linkage kicking around? (Kubota-ish)
this thread has 6 replies and has been viewed 478 times
Old 02-10-2018, 09:19:49 PM
BigBlockChev's Avatar
Default Does anyone have this Fuel Solenoid Linkage kicking around? (Kubota-ish)
I am trying to put together a small generator but don't have the correct fuel solenoid linkage. It would be the same as many Kubota gensets and maybe others like a DKD. Myabe you have replaced your fuel solenoid and still have the old linkage around, PM me if you do. I have looked online but have not found anywhere that has them. Cheers Dan
It's always something simple.
The Feynman method , teach it to a kid , then you understand it.
Old 02-10-2018, 10:26:57 PM
Birken Vogt Birken Vogt is online now
Email NOT Working
Default Re: Does anyone have this Fuel solenoid linkage kicking around Kubota ish
https://www.mcmaster.com/#ball-joint-linkages/=1bilsbq
Old 02-10-2018, 11:17:52 PM
Thanks Birken , I did think of them but have had problems dealing with Mcmaster Carr in the past. I will give it another shot getting them drop shipped to Blaine WA since they won't ship to Canada. Cheers Dan
Old 02-10-2018, 11:48:37 PM
Email NOT Working
That is a bummer, I have found them to be 100% reliable for me and their ordering system should be emulated by all on line vendors.
Old 02-11-2018, 10:54:28 AM
Jim McIntyre's Avatar
Default Re: Does anyone have this Fuel Solenoid Linkage kicking around? (Kubota-ish)
^ true, but as BBC notes, they don't ship to Canada.
Old 02-11-2018, 04:54:42 PM
Motorhead's Avatar
Dan, looked at some 12 valve, mechanically pumped Dodge fuel solenoids and while similar, not as long. Looks like 6mm threaded stock.
https://www.ebay.com/itm/FUEL-SHUT-O...BZyMGb&vxp=mtr
My 1939 WILLYS Pickup.
Bought in 1971
Old 02-11-2018, 05:24:35 PM
I looked at a number of solutions , the linkage has to have an inline ball end linkage and a right angle ball end to actuate the lever. The solenoid I have now is just a straight push and hangs due to the arc of the lever. If I could find a 2 terminal kubota solenoid with linkage for cheap enough that would be great. But so far they are all a bit pricey. Cheers Dan
Kubota D905E Not Getting Fuel to Injectors dalmatiangirl61 Generators & Electric Motors General Discussion 29 04-25-2017 10:23:35 PM
fuel solenoid help R.L.Tunno Onan Generators 22 09-06-2013 12:28:33 PM
Fairbanks jack of all trades fuel pump linkage Tanner Remillard Antique Gas Engine Discussion 3 09-26-2012 09:48:58 PM
IHC Famous fuel pump linkage Tom S Antique Gas Engine Discussion 1 01-09-2012 11:25:38 PM
Fuel Solenoid D Pratt Kohler Generators 4 06-19-2011 11:27:36 PM
