FREQUENTLY ASKED QUESTIONS on Onan Generators
this thread has 11 replies and has been viewed 98459 times
Closed Thread
Old 03-14-2007, 07:10:43 PM
Harry's Avatar
Images: 312
Default FREQUENTLY ASKED QUESTIONS on Onan Generators
This is a thread starter for the purpose of building a F.A.Q. (frequently asked questions) on Onan Generators. This thread will be edited and maintained as a F.A.Q. (Do not drift off topic.)
Check the F.A.Q. on our main generator board too: http://www.smokstak.com/forum/showthread.php?t=47155
EXPERTS: Post away! You may change the title on your post as needed.
When was my ONAN built?
Onan GenSet Model Numbers
Do I have a Magneciter?
Fuel Consumption
Old 03-26-2007, 11:48:13 PM
Default
Onan serial numbers include a build date (MMYYxxxxxxx)as the first 3 or 4 numerals or in some cases a letter for the month (A=Jan, B=Feb etc)and then 2 digits for the year (MYYxxxxxx).
Older sets built before the late 1960's have a letter or a . for the decade, so for example 104.xxxxx would have been manufactured in October 1944. If machine was ever returned for repair etc, the . was stamped over with A. B was 1950's, C 1960's. 124Cxxxxxxx = Dec of "64
Different series of generators changed date coding systems at different times, but there seems to have been a change from letters for the decade to all numbers in the 1960's. The letters for the month seem to have appeared in the 1970's on some of the smaller sets.
Sometimes an engine block casting date can help confirm a build date
Voltage code 15 = a 12 lead reconnectable set. the ones I have seen seem to have been late 60's early 70's.
Engine type K during the 50's - 70's was International Harvester
Here's a link to a post where a magneciter is pictured and some good discussion about them from some experts.
Pictures are on post #8 of
http://www.smokstak.com/forum/showth...ght=magneciter
Discussion near the last postings of http://www.smokstak.com/forum/showth...ght=magneciter
From what I have seen on this board, Magneciters replaced the old manual regulator (rheostat) and electro-mechanical finger regulators probably in the 1950's and were replaced by electronic regulators (VR21 board for example)in the late 1960's
Old 03-28-2007, 05:53:17 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Onan GenSet Model Numbers
a Short Primer for decoding Onan GenSet Model Numbers.
aa.a bbbb-cd/eeeeff An Example 12.5MDJC-3R/9523AA
aa.a is Power Output in Kw (rough approximation)
bbbb is Series of Engine and General Identifier
M=Marine, R=Radiator Cooled, Nothing=Air Cooled
D=Diesel, Nothing=Carberated (Gasoline, Propane, or NG)
JC= J Series Engine , C=Number of Cylinders, A=1, B/E = 2, C/F = 4, a's, B's, and C's, have a 3.25" Bore, E's and F's have a 3.5" Bore
-c is Voltage Code -1 120 Vac only 1Ph, -2 240 Vac 1 Ph only, -3C is 120/240 Vac 1 Ph 4 wire, -3U 120/240 Volt, 1 Ph, 3 Wire, PF 1, -4 120/208 Vac 3Ph Y, -4X 480 Vac 3Ph Y, -5D 120/240 Vac Delta 3Ph w/L1-L2 C-Tapped for L0, -8 127/220 Vac 3 Phase 4 wire (Wye), -15 12 Lead Reconnectable, -18, 12 Lead Reconnectable
____There is some Speculation that -15=Normal Stack Size, and -18=Extended Stack Size. This is UNCONFIRMED
____-53 120/240Vac 50Hz, -518 12 lead 50Hz 12 Lead Reconnectable, -9x 347/600 Vac 3P Y, -99x is Special Order (Consult Data Plate)
d is the Starting Method R=Remote Electric Start, E=Electric Start M=Manual Start
/eeee is the Options Codes (Build Number) "To many to Refernce"
ff is the Spec Code These designate Changes in Specifications from
_____Original Factory Design specs. For J Series Gensets anything
_____with a double letter would be a YD Genend, anything with a
_____single letter is a Magniciter Genend, as the Factory upgraded
_____to the YD Genend a Spec Code AA.
If others have later or additional Information PM or eMail Me and I will update this FAQ.
Bruce in alaska
Old 09-30-2007, 03:17:10 AM
ListerDiesel's Avatar
Default Re: Frequently Asked Questions on Onan Generators
We have started building a few Onan pages on our site to compliment the Kohler information.
There is a 'decoding' page at:
http://www.oldengine.org/members/die.../Interpret.htm
Time is our enemy as usual, we have lots of data but little spare time to get it scanned and onto the site.
Most recently we have been doing European translations of our company website, and we also have more Kohler information part-finished.
Peter
Old 12-16-2007, 04:06:44 PM
TheToolman's Avatar
TheToolman TheToolman is offline
Images: 16
Smile Re: Frequently Asked Questions on Onan Generators
Some of the questions I hear all the time are :
Question: when I push the start button my genset starts. when I release it the engine cuts off
Answer: Post you question in the Onan Forum, giving the complete Model and Serial Numbers
as there are MANY Onan Wiring Diagrams, for MANY different models, BUT our Resident SmartGuys
have the answers to get you going again.
Question: the generator sat a long time , I got the engine running but now will not produce electricity
Answer: Likely, your Genend needs "Flashing", and this procedure is different for each type genend.
Post you question in the Onan Forum, giving the complete Model and Serial Numbers, and one of
the Resident Smartguys can advise you on your particular unit.
Question: where can I get parts?
Answer: First place to look is your local Cummins/Onan Distributor's Parts Dept. then ask on the Onan forum.
Question: only 1 cylinder will fire
Answer: Usually a BAD Spark Plug, or Injector, for specifics, ost you question in the Onan Forum, giving the complete Model and Serial Numbers, and one of the Resident Smartguys can advise you on your particular unit.
Question: when I put a load on the set it does not speed up.
Answer: Most Gensets are Constant Speed type units. The Speed, (and Frequency) is fixed by the design of the Genend.
If your Governor isn't responding to added load, that usually is a Governor Problem. Post you question in the Onan Forum, giving the complete Model and Serial Numbers, and one of the Resident Smartguys can advise you on your particular unit.
Just a few FAQ I hear maybe some one could erase this & start a list
Last edited by BTPost; 05-02-2009 at 01:46:36 PM. Reason: Answers provided by BTPost
Old 01-02-2008, 08:07:06 PM
Images: 12
Default Re: Points for 6.5 NH-3CR
Ben Clark posted this info in another thread, and I thought it might be helpful here.
Standard Ignition part # S13-407, about $18.00
Old 02-13-2008, 10:09:47 PM
Jack Hottel Jack Hottel is offline
Default Fuel Consumption
The fuel consumption question pops up from time to time. Here is the data for a 15.0JC at 60Hz, (1800 RPM):
The gasoline consumption in gallons per hour is:
Load: 0 1/4 2/4 3/4 4/4
GPH: 1.0 1.3 1.6 2.0 2.4
For natural gas with a heat value of 1000 Btu/cubic foot it will consume 255 cubic feet/hour at full load.
For propane with a heat value of 2500 Btu/cubic foot it will consume 110 cubic feet/hour at full load.
Maybe some others can chime in with other units.
Billy Shafer Comment:
Here's dry fuel consumption for one of the larger ones.
70kW with IH 549 V-8 engine manufactured in the 1960's and 1970's
full load-
Propane 2500 BTU/cubic ft. = 400 CF/hr (93.13MJ/cubic Meter = 11.33 cubic Meter/hr)
Natural gas 1000 btu/cubic foot = 1400 cubic feet/hr (37.25 MJ/cubic meter = 39.65 cubic meters/hr)
Onan tech Comment:
Rule of thumb for diesel fuel comsumption on diesel sets: .08 x KW= GPH, or .08GPH per KW.
when replacing onan points with oem onan points: onan oils them so they wont rust, esp on older stock. If you install new points and it wont run, wash off contacts with brake clean. best practice is too just do it before you put em in. This has messed me up before.
let it evaporate before starting unless you want your cap to fly into your neighbors yard.
Old 04-18-2008, 09:57:16 PM
Ted_Cool Ted_Cool is offline
Default Magneciter Info
Hi All,
I have a thread going here with a bit of discussion, theory, diagrams and troubleshooting info for Magneciter gen sets. I kind of like them - miminal electronic 'stuff' to go bad. I can live with brushes - I've got two extra sets my son will probably inherit in 40 years...
Old 04-25-2009, 09:55:29 AM
Onan tech Onan tech is offline
Default Re: FREQUENTLY ASKED QUESTIONS on Onan Generators
use champion h10's instead on h8's in your onan. they run alot better.
Old 10-06-2009, 08:22:47 AM
Default J series brush info
The part number for the brush holder is 212-1064. For the brushes it is 214-0059.
Thanks to Billy for this!
Closed Thread
Onan OTC-33 & OTC-33B Generators ListerDiesel Onan Generators 2 01-15-2013 09:59:14 PM
Onan W2-C, W3-S generators and similar KidDynamo Onan Generators 5 09-09-2011 12:10:35 AM
Not So Old Onan Generators Al Barrs Onan Generators 3 03-26-2008 08:36:49 AM
Onan W2 generators Karl Onan Generators 0 03-25-2008 11:34:16 PM
Used Onan Generators RSlifkin Onan Generators 4 01-21-2008 12:16:30 PM
