Onan Magniciter Theory FAQ
this thread has 80 replies and has been viewed 58216 times
Old 12-17-2009, 10:40:44 PM
Default Re: Magniciter Theory FAQ
here's 4 more schematics of magneciters The plain 04sx and 06sx are shown in a picture posted a while back on this thread.
Name:	02sx with build-up relay [1024x768].jpg
ID:	69393   Click image for larger version
Name:	04sx and 06sx auto flash [1024x768].jpg
ID:	69394   Click image for larger version
Name:	07sx and 102sx magneciters [1024x768].jpg
ID:	69395   Click image for larger version
Name:	onan brush replacement [1024x768].jpg
Old 04-06-2010, 09:37:03 PM
Ted_Cool Ted_Cool is offline
Thanks to Leon, I was able to literally piece this document together.
This is Onan's explanation of the Magneciter, from the J Line brochure.
Maybe no surprises by now, but it's nice to see it all laid out in one go.
Most interesting point: They claim the Magneciter is " Five times faster than brushless type generators"
"Regulation is literally instantaneous since rated voltage is restored
within two seconds after being affected by a load change."
How does that compare to a modern AVR?
Old 05-13-2010, 04:59:42 PM
airbatica airbatica is offline
I stumbled across this little gem of an E-book while trying to find some basic info on magnetic amplifiers.
http://www.archive.org/details/MagneticAmplifiers
And a direct link to the .PDF
http://ia311013.us.archive.org/2/ite...Amplifiers.pdf
The Following User Says Thank You to airbatica For This Post:
  #24
Old 03-16-2011, 03:00:38 PM
BergmanJ BergmanJ is offline
Here's another "take" (gleaned from Marine Training Manual #932-0405 supplied by Richard L. - Thanks Richard) on the same information. See Attached.
Regards, JLB
Name:	Marine Magniciter pp1.jpg
ID:	102702   Click image for larger version
Name:	Marine Magniciter pp2.jpg
The Following User Says Thank You to BergmanJ For This Post:
  #25
Old 04-05-2011, 08:02:50 PM
pvplas pvplas is offline
If you need any info on the magnacitor or how to upgrade as the reactors are not
available, I work in the field for Cummins PG ( Onan) and have developed a few kits for our customers who want to keep the old gems running... I would be glad to share... It would make Gene Tadson smile from above to see his design still in use. Kilowatt.
The Following 2 Users Say Thank You to pvplas For This Post:
  #26
Old 04-05-2011, 09:48:25 PM
I'd love to take a look at what you have come up with.
I think some of us are learning the dark art of coil winding - just in case.
Isn't it funny how the magneciter isn't designed with fuses in the circuit ???
Old 04-06-2011, 07:49:58 AM
PVPLAS,
Please post that information here for all to see.
Thank you very much!
Regards, JLB
Old 05-08-2011, 03:47:40 PM
Leon N. Leon N. is offline
Default Re: Magneciter differences -06SX
Hello Ted:
Just happened to review the Magneciter FAQs. Very interesting. Re your question: Does anyone know when/where/why the different 06SX magneciters were used? I think I found the answer in the Onan JB Operators manual, # 967-320. See page 23 for the appropriate the parts key number. And on page 44, the note indicates the 06SX series was used on the 50 cycle plants.
Leon
  #29
Old 05-25-2011, 01:10:20 AM
Argent88 Argent88 is offline
Onan magniciters are not like the Caterpillar SRCR gen sets . The Cats require over 40 amps DC to the rotor through the brushes, and any problems with the brush and slip ring contact causes sparks that will eat up the slip rings . Or cause the regulator to blow one ,or all of its three fuses or go out altogether. It was not a good design when compared to the Onan Magniciters .
One reason was the Onan didn't use the high amp excitation like the Cat did. And if you cant get your magniciter to work. You can remove it all together ,and contact Paul Huber at Powertronics in Kerville Texas and buy a UVR500 voltage regulator for around $225.00 .
Couple it up to a SE350 module for around $ 35.00 . Then just run off your old brush holder a set of F1 & F2 wires to the SE350 Pos and Neg post . You can mount this rig inside your control panel because it is about the size of a pack of cigarettes .
I still know customers that let us do this, and are still running the older brush type Onan gen sets over 250KW on their Farms and Dairy's with no problems at all .
Cant say that about the Cat SRCR gen sets .
Old 07-15-2011, 11:28:30 AM
jdzumwalt jdzumwalt is offline
Ted, can you provide me with info for locating new or used magnaciter 06sx1n3b, now replace with pn 305-0899 kit, origioinal pn was 209-0100 for magnaciter. cant find info for power tronics in subsequent threads, do you have any info regarding this. Thanks. jd
25kW Onan 3 phase 208 W/Magniciter Ford 6 mrmuzic Onan Generators 57 06-17-2012 11:43:06 PM
Onan YD vs Magniciter GHanners Onan Generators 14 05-20-2012 06:48:39 PM
Onan 30EK UR, Magniciter 07SX1N1C high voltage franciscanfriars Onan Generators 35 09-22-2011 08:01:59 AM
Theory of low compression on Onan CCKs c east Onan Generators 10 04-14-2011 05:27:55 PM
