Onan Magniciter Theory FAQ
this thread has 80 replies and has been viewed 58156 times
Old 07-15-2011, 12:17:04 PM
Ted_Cool Ted_Cool is offline
Default Re: Magniciter Theory FAQ
Magneciters are extremely rare, and expensive.
You can find Power-Tronics here
830 895 4700
Old 09-07-2011, 07:27:27 PM
loonatickman loonatickman is offline
pvplas - i've got a 12MDJC-3R/2268R and can't get any voltage from it. If you have any manuals or info that might help in diagnosing this I'd really appreciate a copy. My Exciter is the 06SX1N3B also. It's a great diesel generator and I'd really like to get it working again for the coming winter season. Mike m_olesnevich@vernonsoft.com
Thanks.
Old 08-24-2012, 02:47:41 PM
BergmanJ BergmanJ is offline
Folks,
I have attached the data sheet for stud-mount power diodes which make a good replacement for the original Onan's.
---------- Post added at 01:47 PM ---------- Previous post was at 01:41 PM ----------
Well -- I thought that I did!
They are Ruttonsha International Rectifier, Ltd. 16FL40 [400V PIV] (or 60 [600V], or 80 [800v]), for one side (two diodes) of the power bridge. 16FLR40's. etc., are "reverse polarity", for the other two diodes of the power bridge.
These are inexpensive, available from Mouser, and a very good replacement (exact stud-mount as original).
Regards, JLB
The Following 2 Users Say Thank You to BergmanJ For This Post:
  #34
Old 08-24-2012, 04:39:16 PM
GHanners GHanners is offline
I tried to buy some mouser tells me 1 is in stock 1 is non stock with min order (i forgot the min order) do you have any of these spare or another source ?
Old 08-24-2012, 06:16:40 PM
yes, always need to check stock with Mouser before you finalize your order. I usually was able to find a higher amperage or higher voltage etc that was instock that would work.
digikey and others should have them. also look on ebay. Usually are some there as well. I have a cache of my own so I don't have to order every time I need one or two.
The Following User Says Thank You to Jim Rankin For This Post:
  #36
Old 08-25-2012, 12:06:24 AM
what is the stock rating for the diodes ?
16a 400v ?
or is that a higher amp/volt to prevent failure ?
the ones you have listed are fast recovery it's only 60hz will std one work ?
16F40 & 16FR40 ?
what about voltage diodes p/n 305-0240 anyoine have a spec on them ?
Fire Down could that be on shut down ?
as the rpms go down the hz go down so the voltage should rise to the field ?
or am i missing something
Old 08-25-2012, 12:28:35 AM
Power Power is offline
I posted this before - did an ebay search and bought stuff off these folks - very reasonable - $2.95 incl. shipping direct from China, which is same place they all come from. I prefer American made, but seems they are all made in China now. On this replacement, Original was 25 amp 400 volts, I upsized a bit.
BRIDGE RECTIFIER -Model: KBPC3510 / 35A 1000V NEW
Seller:
Member id goodbuy711 ( Feedback Score Of 57928)
99.8% Positive feedback
Save this seller
| See other items from this seller
| Visit store: ALLPARTSPIPE
  #38
Old 08-25-2012, 03:08:58 PM
'Fire down' refers to the point where the magneciter cuts the voltage to the field and it begins to collapse bringing generator terminal voltage down.
It should behave about like pulse width modulation. If the load is low, magneciter send voltage to field, which raises the voltage and it reaches "fire down" which causes the excitation to drop. Then as terminal voltage declines, the magneciter turns back on and you get another pulse which brings the voltage back up. With some resistance and inductance in the circuit, output voltage doesn't bounce around noticably.
Increase load and the voltage takes longer to come up, so the magneciter stays "on" more and "off" less. Above maximum load, if no breaker or fuse trips first, magneciter stays "on" full time and generator terminal voltage never reaches the 'fire down' voltage. Magic smoke soon appears!
  #39
Old 08-27-2012, 07:58:38 AM
GHanners,
In response to #36 above: Yes, "regular" recovery is just fine; and, yes, the listings shown are "better" than the originals (more current capacity, and higher PIV).
"Power" (in #37) also has a good replacement for the whole bridge; my recommendation was to provide an "original-mount" part, which may seem easier for some folks.
Regards, JLB
Old 01-29-2013, 09:25:59 PM
Generactech Generactech is offline
Default Re: Onan Magniciter Theory FAQ
I have several magniciter onan gens in my stash of older units. I have been searching for a simple way of being able to convert these 480 volt units to a more usable 120/240 unit.
I was looking at changing the 425 ohm resister (#3) to a 200 ohm to lower the voltage going into the voltage control reactor. any ideas as to helping me out would greatly further my efforts. I was thinking if it worked to add a DPDT switch to change the out put from 120/2540 to 480/277?
25kW Onan 3 phase 208 W/Magniciter Ford 6 mrmuzic Onan Generators 57 06-17-2012 11:43:06 PM
Onan YD vs Magniciter GHanners Onan Generators 14 05-20-2012 06:48:39 PM
Onan 30EK UR, Magniciter 07SX1N1C high voltage franciscanfriars Onan Generators 35 09-22-2011 08:01:59 AM
Theory of low compression on Onan CCKs c east Onan Generators 10 04-14-2011 05:27:55 PM
