Onan Magniciter Theory FAQ
this thread has 80 replies and has been viewed 58230 times
Old 11-21-2017, 03:13:57 PM
zuhnc zuhnc is offline
Default Re: Onan Magniciter Theory FAQ
The images are measured at the F1 and F2 terminals. DC input to the field. Very sharp rise, and then the decrease to zero volts No negative-going pulses. Two "pulses" are one complete cycle of the AC waveform, hence the frequency showing double actual AC frequency. I will get images of the AC waveform and publish them. There is very little discernible "notch" in the AC waveform. The notches are on the "falling" (toward zero crossover) on both the positive and negative sides of the AC waveform. The peaks of the DC waveform are at approximately 120* and 300* of the AC cycle. Hard to tell; I don't think I have a way to measure that angle or position. But, the images I originally published show clearly where they occur, even though the measuring procedure was faulty. The more I read on magnetic amplifiers, the easier it is to determine exactly how the Magneciter operates. Information is a good thing, along with all the very knowledgeable Stackers! zuhnc
25kW Onan 3 phase 208 W/Magniciter Ford 6 mrmuzic Onan Generators 57 06-17-2012 11:43:06 PM
Onan YD vs Magniciter GHanners Onan Generators 14 05-20-2012 06:48:39 PM
Onan 30EK UR, Magniciter 07SX1N1C high voltage franciscanfriars Onan Generators 35 09-22-2011 08:01:59 AM
Theory of low compression on Onan CCKs c east Onan Generators 10 04-14-2011 05:27:55 PM
