How to: Convert ONAN CCK & MCCK 6.5KW to OEM Electronic Ignition
this thread has 52 replies and has been viewed 74761 times
Old 06-21-2012, 06:32:57 PM
roundrockcrawler roundrockcrawler is offline
Question Re: How to: Convert ONAN CCK & MCCK 6.5KW to OEM Electronic Ignition
Does any one know the year Onan went to electronic ingnition, since we can't get the kit maybe we can buy dead late model Gen sets and change out EI Mod to older units, Also will the elec ignition from a 6.5 work in a 5.0
Old 06-29-2012, 09:27:25 AM
Default Re: How to: Convert ONAN CCK & MCCK 6.5KW to OEM Electronic Ignition
Or another Idea, I had is can we use a EI from a later model 2 cyl engine, on on older CCK,s , I have very limited knowledge and less understanding about the electrical part of an motor but I don't see why this wouldn't solve the problem of discontinued parts.
Old 11-28-2012, 11:16:43 PM
Beavisz Beavisz is offline
Really nice instruction.. Good Job.. but what happens if obama hits us with an EMP ? solid state will be fried.. MAGNETO will still work ... LOL
Old 03-07-2013, 11:13:25 AM
jwrape jwrape is offline
Then I go Solar. LOL!
Old 06-26-2013, 11:00:19 PM
acesneights acesneights is offline
Will this work on a 4.0 cck ?
Old 06-28-2013, 07:19:22 AM
If it has the same style points set it will. I am not sure what the 4.0 cck looks like. I have only worked on my 6.5K MCCK and my 3.0 MAJB
Old 08-01-2013, 06:42:58 PM
RocketmanTn RocketmanTn is offline
I have a 705JB-3R / 0669109735, can this generator be converted to Electronic ignition? Running Propane. Just got this Generator few days ago. Any info will help and thanks.
Sterling
Old 08-06-2013, 10:26:15 AM
poppi poppi is offline
so as of this date Tuesday 5 August 2013 no one makes am electronic ignition to replace the point system on a ONAN CCK 5.0 3CR engine ?
thanks in advance
The Following User Says Thank You to poppi For This Post:
  #39
Old 08-06-2013, 07:32:01 PM
MBB MBB is offline
Post your questions in the regular area not in the sticky it wont get confusing that way. In a short answer to both your questions yes both can have electonic ignition or a Pertronics kit.
The Following User Says Thank You to MBB For This Post:
  #40
Old 02-10-2014, 04:59:22 PM
McDammitt McDammitt is offline
Default Re: How to:Convert ONAN CCK & MCCK 6.5KW to OEM Electronic Ignition
From that point on I am confused. You don't show the plunger installed under the ignition. I have a CCKA and the plunger is too tall to fit, also there is a lip on the plunger holder.
Trying to convert to Electronic ignition w/Magna Arc jwrape Onan Generators 61 08-06-2008 01:25:58 PM
electronic ignition Alan R Small Air Cooled Gasoline Engines 5 05-03-2007 08:49:23 PM
Electronic Ignition Gunny Onan Generators 22 01-31-2007 07:21:48 AM
Electronic ignition for Onan BF-MS 3271E lwhiway Small Air Cooled Gasoline Engines 0 09-13-2006 04:01:49 PM
Need a electronic ignition for IH Tractor Kevin M. Antique Engine Archives 1 03-20-2003 03:31:21 PM
